why should I care a...
[Closed] why should I care about lube?
[#597520]
I use Finish Line wet lube for most of my UK riding, switching to Finish Line Dry if I go to Spain in the dusty mountains. My chain turns, my wheels turn as a result. Have I "accidently" chosen lubes that work? When do I know a lube is rubbish?
Posted : 02/06/2009 9:18 am
when you can hear the metal complaining
Posted : 02/06/2009 9:20 am
OK, so never had that then - at least not from the chain. Great, no point inventing something to worry about.
Posted : 02/06/2009 9:33 am
I use dry lube all the time just make sure my chain is clean and relube it before I ride.
Posted : 02/06/2009 9:40 am
So you use wet lube in the wet, dry lube in the dry, and it works? Crazy! 😉
Posted : 02/06/2009 9:48 am
there was a time when I thought you used wet lube if the conditions were dry. Why not? The chain is dry so wet it 🙄
Seriously though, lube seems to be obsessed about (almost) as much as tyres by some people. I thought I was missing out on something. Apparently not
Posted : 02/06/2009 9:49 am
Wot no KY comments?
Posted : 02/06/2009 10:03 am
I think that some people obsess about lube because they hate black chain gunk. One way to get round this is to use dry lube all the time, but it tends to wear off very quickly in the wet.
Posted : 02/06/2009 10:07 am
Use Green Oil which works in wet or dry conditions and doesn't pollute the countryside with petrol chemicals.
Lubes your chain and gives you bunny hugging credentials!
Posted : 02/06/2009 10:09 am
...and can't be bothered to clean their chain??
Posted : 02/06/2009 10:14 am
The Environmental credentials, or lack there of, of bike chain oils are pretty heavily overstated.
Given the very small volume on a chain, its loss whilst moving through the country will leave a very diluted trail at low concentrations. Low concentrations and minute volumes of oil like this are easily attenuated by natural systems, the largest contributor to which will be microbioligical degradation.
Environmentally unfriendly oils are much more damaging to the environment as a whole at the point of extraction and manufacture, rather than polluting the countryside.
It would be a different story for oils designed for engine driven devices,; there is significantly more volume involved, and during use, the oil picks up products of incomplete combustion, the majority of which are carcinogenic/toxic. Some of these are relatively persistent in the environment too.
Posted : 02/06/2009 10:22 am
Scienceofficer - what is the environmental impact of lubes employed as marital aids?
Posted : 02/06/2009 10:24 am
Posted : 02/06/2009 10:25 am
I was thinking about lube on Saturday's bimble, after getting a bit bored of Green Oil. Specifically I was thinking about chain wax, maybe after seeing the ad for Pedros Chain Wax and given the promise of a long hot dry summer? (JINX!) Anyway checked up on the Pedros stuff and HOW MUCH?
Then I wondered is there any reason not to use motorcycle chain wax, specifically this stuff?
[url= http://www.bobpickett.co.uk/bkit/rockoilchainwax.htm ]Rock Oil Chain Wax Review[/url]
Posted : 02/06/2009 10:30 am
Bimbler, see here: http://www.singletrackworld.com/forum/topic/which-lube
Posted : 02/06/2009 10:32 am
3 in 1. All the time for last 10 years and in all conditions.
Never had a problem.
Posted : 02/06/2009 10:34 am
Thanks. I guess that (kinda) answers my question then. Cool
Posted : 02/06/2009 10:45 am
I use that, but dust seems to stick to it like dog droppings to a blanket.
Maybe I'm using too much (wazz it all over the chain then wipe off excess with a rag)
Posted : 02/06/2009 10:47 am
