Why is 29 faster th...
Why is 29 faster than 27.5?
I have recently started putting serious mileage on my Big Al.
It replaces a 27.5 Commencal Meta HT.
The new bike is perhaps 500g heavier.
Build is similar. Geo not massively different.
The new bike feels faster or I feel less tired. It particularly feels like I can climb with less effort.
I didn't realise the wheel size made such a difference, but why? They're heavier to start with.
My fitness is really good at the moment so perhaps other variables are getting in the way. Or a bit of placebo effect?
[url= https://i.ibb.co/TgbwknF/Screenshot-2024-05-23-20-41-37-264-com-miui-gallery-edit.jp g" target="_blank">https://i.ibb.co/TgbwknF/Screenshot-2024-05-23-20-41-37-264-com-miui-gallery-edit.jp g"/> [/img][/url]
Posted : 23/05/2024 9:39 pm
If there is a track difference it’s rolling rolling resistance in rough terrain. Basically a bump picked back less on a larger wheel. Think about a skate board off road. 0.5kg is not much weight.
However on less severe terrain my 650b gravel bike is faster than my 29er fs bike
Posted : 23/05/2024 9:48 pm
White is about the slowest colour as well!!
slowol, burgatedicky, big_scot_nanny and 9 people reacted
Following my mate down Super Swooper at Dyfi, with him on a 27.5 and me on a 29er, on sections that we were freewheeling I had to brake to keep from overtaking him, purely because the 29er rolled better.
Posted : 23/05/2024 11:10 pm
This effect is very obvious when your children move up through wheel sizes. My eldest has gone 14”, 20”, 24”, 27.5” and each bigger bike has been significantly heavier than the one before (and she’s light for her height). But the bigger wheeled bike is noticeably faster. I remember when my son went from 14” to 20” he was SO much faster!
Posted : 23/05/2024 11:11 pm
 mboy
Lower angle of attack over bumps, longer contact patch for a given tyre size, hold momentum better...
The higher weight and the slower acceleration downsides are/were far less of a problem than the nay sayers would have you believe, but the upsides of larger wheels are significant.
Posted : 23/05/2024 11:14 pm
jameso, J-R, CheesybeanZ and 7 people reacted
You really need to use a stopwatch to compare, how you "feel" is often not a good guide. You also need to make sure that the bikes you are comparing are running the same tyres. My guess is that a 29er will be slightly faster, but that tyres will make a much bigger difference and that there will probably be trails where a 27.5er is slightly faster.
Posted : 23/05/2024 11:34 pm
silvine and silvine reacted
Fair enough! I was running Rekons on 2.8F and 2.6R on the Commencal.
Now Rekon 2.6F and Nobby Nic DD 2.4R.
Is the contact patch similar in area at the same pressure between the 2 bikes, albeit of a different shape?
I can agree that very tight and twisty trails might not suit the bigger bike.
I am mostly talking about effort rather than technical or handling ability so far.
But you're right, perception and reality may be quite different particularly as the Commencal was very stiff so perhaps I used to be more fatigued/battered than with the very comfy Big Al!
Posted : 23/05/2024 11:43 pm
What I figured out when I first switched, was that when you think about the rollover thing you naturally tend to think about invidivual bumps, ie bigger stuff, but that's not really where it makes the difference I think- it's the actual amount of bumps that counts. Little ones get turned down from "a very small bump that you barely notice but that slows you down a little bit" to "a tiny bump that you barely notice and slows you down even less" and slightly bigger ones get turned down into little ones. It's just that this happens absolutely all the time unless you're on really smooth surfaces.
The big hits barely matter most of the time, because you deal with those by actually riding over them, moving your body, using the suspension etc. It does still help but it just doesn't happen enough to really add up on most trails. But washboard chatter on a fire road slows you down a tiny amount but a thousand times
There's more complicated stuff with tyre deformation, for hte same pressure you get a slightly different shaped contact patch on the bigger wheel, longer and narrower. So that'll tend to give a wee bit less loss from hysteresis since you're basically pushing a smaller, narrower "bow wave" of tyre. But then we probably don't use the same pressures so that's where it gets just messy. TBF actual tyre dynamics are super complicated and a bit unintuitive
Posted : 24/05/2024 12:00 am
Ride a 20" wheeled BMX off road and you will see the effect exaggerated.  They slow down so quickly it feels like you have the brakes rubbing.
Posted : 24/05/2024 6:55 am
jameso and jameso reacted
At the same pressure they'll be the same area but a slightly different shape, larger OD wheel will have a longer thinner contact patch that may add some side to side stability in theory, but with tread and a loose/soft surface considered I think it's hard to say how much of a factor it is.
It's this -
The larger OD wheel doesn't drop into holes so far so it reduces amplitude of bumps at the axle -  rolling resistance is lowered, lower movement of the mass of you and the bike over bumps and the effect that has on the tyre deformation.
On the acceleration and heavier wheels point, a larger OD wheel spins slower at a given speed anyway so all we're concerned with is moving along or up (rather than rotating) 6-7% more wheel weight if rim + tyre type is the same. When I first got used to a 29er I felt I was holding speed better overall so there was less need to accelerate back to speed. 'Felt' isn't quantifiable but the way the bigger wheels roll down gentle descents you know well is hard to miss and all in all I'd say efficiency was higher on a longer ride with a larger wheel despite the added weight.
Where I can really nerd out on this is road/gravel bikes for a mix of bad road surfaces and basic gravel use, where bump size and frequency is different and you can deal with a lot of it via tyre volume (eg 650B) on a smaller OD rim because the size of the bumps is generally much smaller.. but years on I'm still split on the 2 rim sizes there.
Posted : 24/05/2024 9:14 am
A frame builder did a recent comparison, and pretty much concluded that the only real tangible difference is the gyroscopic effect at speed. yes we know there is improved roll over but when you actually look at what it is like in the real world it would be unperceivable
Conversely, i am so much more a fan of the way my 27.5 bike climbs compared to the 29ers I've had. That being said, comparing my 29 hard tail to my Top Fuel, tyre choices, riding position etc, and the FS Top Fuel was a much nicer pedal, the hardtail being a horrible climber (Sonder Signal, dt xm481 with 2.6 enduro casing tyres)
Posted : 24/05/2024 9:21 am
“ A frame builder did a recent comparison, and pretty much concluded that the only real tangible difference is the gyroscopic effect at speed. yes we know there is improved roll over but when you actually look at what it is like in the real world it would be unperceivable”
I don’t know who this frame builder is but this sounds like a classic example of a poor executed scientific experiment leading to incorrect conclusions.
In the real world, off-road, bigger wheels roll faster if you keep all the other variables the same.
Posted : 24/05/2024 9:28 am
cerrado-tu-ruido, Del, matt_outandabout and 3 people reacted
I'd agree with Northwind's comments about the cumulative effect of the bumps being what you notice.
When I first got used to a 29er I felt I was holding speed better overall so there was less need to accelerate back to speed. ‘Felt’ isn’t quantifiable but the way the bigger wheels roll down gentle descents you know well is hard to miss and all in all I’d say efficiency was higher on a longer ride with a larger wheel despite the added weight.
I'm not a physics person, but it feels to me like the way a larger flywheel holds momentum better and longer.
Not that I have a huge collection of flywheels 😀
Posted : 24/05/2024 9:29 am
It's because your wallet has been made much lighter.
Posted : 24/05/2024 9:33 am
It's pretty unusual to have a 27.5 and 29er with exactly the same wheel base, front and rear mechanical trail, front and rear centre, BB drop, suspension corrected for the improved roll over etc.
In fact, it's impossible to ever completely recreate all the same geometry between 27.5 and 29ers.  Especially when you start taking into account how the geometry changes as you turn the handlebars and the suspension moves.
I don't think bigger wheels are inherently faster.  If you took a 2011 29er and put it up against a 2018 onwards 27.5 you'd most likely find the 27.5 bike was much faster.
It also comes down to riding style.  A bigger wheel will roll over things better but if you are the kind of rider who is very active and constantly pumping to gain or maintain speed then you might find you get less out of a 29er than you would on a 27.5.
Probably with the majority of riders on the majority of trails 29er is faster (at least for the front wheel) but I don't think it's a universal truth.
Posted : 24/05/2024 9:34 am
it was a big UK? steel frame builder, can't remember who
yup, big wheels maintain momentum, but in mountain biking you can be constantly decelerating and accelerating. so additional energy is expended there. I'm pretty sure he wasn't poo pooing any of the arguments, just saying that they were a drop in the ocean compared to the gyroscopic effect bringing increased stability
Posted : 24/05/2024 9:36 am
It’s because your wallet has been made much lighter.
😂. That certainly should be a factor.
But the net cost was zero courtesy of the CRC crazy prices. I sold the frame for more than the new cost of the Big Al frame for starters.
In fact I think the new bike made a little money.
Posted : 24/05/2024 9:52 am
It’s because they make the trails come alive innit.
Posted : 24/05/2024 9:53 am
No, for that you'll have to wait for the soon to be announced goldilocks 28.25" wheels (3mm increase in BSD over 27.5)
Posted : 24/05/2024 10:07 am
I don’t think bigger wheels are inherently faster.
They do roll a bit faster, as explained above, but tyres will make a bigger difference than a 40 mm difference in wheel size.
Posted : 24/05/2024 10:09 am
For a while I had a 27.5 hardtail and a 26 FS. Going back to the latter after a few months it was noticeable how much forward momentum was lost on deep roots and larger step-ups.
Posted : 24/05/2024 10:14 am
..a drop in the ocean compared to the gyroscopic effect bringing increased stability
I'd say they were mistaken. Gyroscopic force is a classic Room 101 answer in bike stability and handling. It's got very little to do with it at average bike speeds. Maybe at full DH speed in the air there's some difference in feel. But on the ground, larger wheels are rotating slower at a given speed so the only difference in gyro force is from that 6-7% change in weight which will mean a similar 6-7% change in gyro force. If you can feel that you'll feel it equally as you change tyre weight within the same wheel size, like from an 850g to a 900g tyre. It's just not a factor esp. compared to the potential change in rolling resistance.
..Ahh, I'd missed the wheelsize chats : )
Posted : 24/05/2024 10:19 am
However, you'd generally be using very similar tyres on either wheel size for the same application - whether that's gravel or technical MTB.
Yeah, but as was also explained above they also won't accelerate as fast and some riders use every slight dip they can find to maintain and gain speed.  You can't do that as effectively with bigger wheels.
Now admittedly not all riders ride like this.  In fact, maybe the majority of riders don't ride like this.  And of course, once you get into steep technical terrain it becomes less of an issue.
But even then, when things get really steep and technical, you are still looking for every minor dip to actively drive the wheels into so that you can gain enough traction to brake effectively (sort of reverse pumping).
But ultimately, if it was a universal truth that 29ers were faster than 27.5, the resale value of a 2011 29er would be a lot higher.
Posted : 24/05/2024 10:20 am
Wheels are just the final gear, so the bigger the wheel the better the ratio for transforming power into speed. This is why 1x with it's tiny front ring is a silly modish fashion.
Most of my long standing fastest times on Strava are on a 26'er
With a triple chainset....
Posted : 24/05/2024 10:24 am
 DT78
Completely depends on the trail you are riding, and its the combination of wheel size / wheelbase / geometry
I have an old school 26er charge duster, on certain very tight twisty trails (like the labrynth at swinley) I'm faster overall on it that my ultra light scott scale 29er.
You also have 'total' speed vs acceleration.  I think I have a faster sprint on the smaller wheels, but overall the longer the section I'm timing the more the bigger wheels tend to win out.
You then have the 29 HT vs FS.  I also have a scott spark, which is pretty much faster everywhere than the scale, except up steep inclines.  But the FS feels slower and is less fun.  But the timings show its faster.
All bikes are black so its not the colour making a difference 🙂
Posted : 24/05/2024 10:31 am
Is that because you were younger and fitter when on the 26".  My fastest times on Strava are from 10 years ago when I was 46 rather than 56 and not sure the bike I was riding was as relevant.
Luckily I have just bought myself a 26" with a triple so will see how my times go over late summer when I am typically get the fastest times.  Although the bike is old I am running tubeless Mezcals which certainly feel fast enough to be in with a chance.
Posted : 24/05/2024 10:37 am
I don't think comparisons like, 'My 2010 26" FS is way worse than my 2020 29er hardtail' really tell us much, to be honest.  All that tells us is that bikes have improved over 10 years.
To really compare the wheelsizes I think you have to get something like a Geometron G1 with all the flip chips and get the geometry as similar as possible.  Even then it's not going to be identical and the bike was most likely designed with a particular wheel size more in mind.
There's been a few videos on YT where people have done just that.  I couldn't find the one where someone went full 27.5, mullet, and full 29er but the conclusion was that there wasn't that much difference but the 29er probably got less hung up on roots.  Don't think either one talked about how easy each version was to pump though.  Here's the PB one about mullet and full 29er:
Posted : 24/05/2024 10:39 am
I still remember first ride on a Niner EMD after a couple of decades on 26" wheels.
Oh.
My.
Word.
It just rolled like a juggernaut over the usual Houndkirk Moor trail debris and rocks. It just sustained speed where my 26" would have dropped into holes or square edge steps would have noticeably knocked back some momentum. Over the course of a longer ride, this added up to less effort to sustain speed but also more comfort.
I have 27.5 currently and plan 29 for my next bike.
(I will put aside an early QR SID and road 700c rims with a too wide early WTB tyre mounted, which flexed like crazy in more gnarly terrain and corners...eveything else was superb.)
Posted : 24/05/2024 10:43 am
BMX trails riders are on 20". 4X racers will be on 27.5". Long distance racers will be on 29". Fast DH riders tend to be on MX bikes. It's terrain, pedalling and handling-dependant.
What we can do is take all of those variables out and look at roll-down tests, if a larger OD wheel or higher volume tyre is seen to be faster there you have something that's more efficient and it's a passive advantage, it needs no input from a rider to have that advantage. So 29" has objectively greater rolling efficiency. Then we need to get into whether it's suitable for the rider and terrain, which is all subjective stuff to some extent. Or how the amount of suspension changes how a wheel rolls, or how a wheel size/weight influences suspension action.
Posted : 24/05/2024 10:48 am
  I couldn’t find the one where someone went full 27.5, mullet, and full 29er but the conclusion was that there wasn’t that much difference but the 29er probably got less hung up on roots.
I've spent a day at Ae forest, riding the same bike with the rear wheel switched between 27.5 and 29. Geometry corrected to an extent.
Yes - hanging up more on roots and in holes was the main difference descending.
Mullet more composed in steep terrain and more "flickable" (as we used to say), 29 just held speed better.
Also did a lot of comparison in the Alps last year, basically: Pila (fast & rocky) = full 29 better, Verbier (steep and twisty) = mullet better.
Posted : 24/05/2024 10:56 am
I don’t think comparisons like, ‘My 2010 26″ FS is way worse than my 2020 29er hardtail’ really tell us much, to be honest. All that tells us is that bikes have improved over 10 years.
My comparison was a 2005 26" Orange Sub-5 and a 2007 Niner EMD of similar geometry...
[url= https://live.staticflickr.com/2346/2223390572_11f94e7a5e_k.jp g" target="_blank">https://live.staticflickr.com/2346/2223390572_11f94e7a5e_k.jp g"/> [/img][/url][url= https://flic.kr/p/4otsyd ]Niner Geometry[/url] by [url= https://www.flickr.com/photos/matt_outandabout/ ]Matt[/url], on Flickr
Posted : 24/05/2024 11:01 am
"So 29″ has objectively greater rolling efficiency. Then we need to get into whether it’s suitable for the rider and terrain, which is all subjective stuff to some extent. Or how the amount of suspension changes how a wheel rolls, or how a wheel size/weight influences suspension action."
Exactly!
"I’ve spent a day at Ae forest, riding the same bike with the rear wheel switched between 27.5 and 29. Geometry corrected to an extent.
Yes – hanging up more on roots and in holes was the main difference descending.
Mullet more composed in steep terrain and more “flickable” (as we used to say), 29 just held speed better.
Also did a lot of comparison in the Alps last year, basically: Pila (fast & rocky) = full 29 better, Verbier (steep and twisty) = mullet better."
And this totally correlates with everything I've heard about mullet vs full 29. Also, I suspect once you get to 200mm+ of rear travel and/or high pivot the full 29"s advantage on fast and rough gets lost somewhat under all the rear suspension action.
Posted : 24/05/2024 11:18 am
We have done it with two identical bikes. In the UK,  Alps, Lake Garda and Finale. One set up 27.5 and the other 29. Swapping riders between bikes. The red one was always faster. The blue one was more flickable. Mullet didnt feel right.
20200925_144848
Posted : 24/05/2024 11:38 am
Wheels are just the final gear, so the bigger the wheel the better the ratio for transforming power into speed. This is why 1x with it’s tiny front ring is a silly modish fashion.
I don't understand this. If I compare the x1 12 speed gearing to my old triple, there is hardly any useful difference.
And that's before the benefits are taken into account.
To me x1, which I started in 2010, has massively improved my enjoyment of riding MTB. I would put it on a par with droppers
Posted : 24/05/2024 11:45 am
Yeah, but as was also explained above they also won’t accelerate as fast and some riders use every slight dip they can find to maintain and gain speed.
You can't gain speed by riding into a dip because you will lose it as soon as you climb out the other side, all this will do is throw you off your pedaling and slow you down. The acceleration thing is mostly a myth too. A bike with smaller wheels will be faster through tighter trails where you are constantly changing direction, but the slight increase in weight of a larger rim and tyre won't really make a huge difference to your acceleration considering that the bike plus rider generally weighs 70kg or more.
Posted : 24/05/2024 12:05 pm
I was a 1x person, even had it on a road bike when had one.  Now using a triple which I don't think I have used for well over 20 years but I am liking it, very much to my surprise.  The 7 speed cassette is less caring due to wider spacing and it just feels really smooth and shifts perfectly (pretty good seeing that it is almost 30 years old!) and I also get a 42/11 which is good for fast stuff.
Anyway, none of that has much to do with 29 vs 27.5.
Posted : 24/05/2024 12:15 pm
You can’t gain speed by riding into a dip because you will lose it as soon as you climb out the other side, all this will do is throw you off your pedaling and slow you down.
It's this kind of comment that illustrates what wildly different understandings we all have about what mountain biking actually is.
Posted : 24/05/2024 12:17 pm
"You can’t gain speed by riding into a dip because you will lose it as soon as you climb out the other side, all this will do is throw you off your pedaling and slow you down."
You pump into the dip and you suck/pull the bike out of the dip. You're not pedalling but you're putting energy into the bike with your whole body, to generate/maintain speed. Pumping is one of the most fun and flowy things in mountain biking and the allegedly reduced pump from bigger wheels is what put off moving from 26 to 27.5 to 29.
However, I think on all but the smoothest trails I prefer how a 29 pumps vs smaller wheels because the "noise" of little bumps/rough is flattened more, momentum is maintained more and you can get on with the fun of pumping the trail. 29" singlespeed hardtail (with a long dropper post so you can MOVE) is just so much fun on singletrack for this reason.
Posted : 24/05/2024 12:34 pm
^^ this is literally pumping in and out to increase speed right?
if unsure, Ben Cathro did some nice videos on it
Posted : 24/05/2024 12:35 pm
Totally agree.
I find myself trying to pump everything on the trail (gigidy).  No depression or bump is safe and especially in corners I love unweighting on entry and then driving the wheels into the dirt and either drifting or making that nice schralpy sound (or crashing).
I probably look like a chimpanzee having a seizure but I'm having fun which is the main thing 🙂
Posted : 24/05/2024 12:47 pm
Del and Del reacted
I found in the transition from 26 (HT and FS) to 29 that the 29 climbs better, rolls better but takes a bit more thought and energy to turn. It's like there's more forward momentum keeping a straight line.
Posted : 24/05/2024 1:15 pm
Smaller wheels can feel more able to generate speed from downslopes in places but you'll lose momentum more easily in others. You put in energy to gain speed that you lose elsewhere - zero gain on an average trail (no such thing but you know what I mean). It's very terrain-dependant outside of a BMX track. Or it's about how long you ride for and can keep up that bump-pumping riding style.
I'm not even sure if it's the wheelsize that does it, there's the reduced BB drop and rear-centre of a smaller wheel bike to think about. If the BB to axle relationship was the same and the wheel weight was the same, the pump could/should be the same - but who'd want 29" wheels on a pumptrack or 4X course because of the corners, or the longer forks, etc.
Posted : 24/05/2024 1:19 pm
You pump into the dip and you suck/pull the bike out of the dip. You’re not pedalling but you’re putting energy into the bike with your whole body, to generate/maintain speed.
If you want to go fast, pedal the bike. When you have a choice of skirting dips and pedaling across the flattest line available or deliberately seeking out dips and pumping, you'll use more energy and go slower if you pump rather than stay seated and just pedal as hard as you can. Go to a pump track and compare your lap time pedaling with no pedaling.
Posted : 24/05/2024 1:33 pm
"If you want to go fast, pedal the bike. When you have a choice of skirting dips and pedaling across the flattest line available or deliberately seeking out dips and pumping, you’ll use more energy and go slower if you pump rather than stay seated and just pedal as hard as you can. Go to a pump track and compare your lap time pedaling with no pedaling."
I'm not being paid to win races, I'm riding my bikes for fun in my free time. So I shall continue to ride the way I find most fun - which will involve a lot of pumping!
The joy of a 29" singlespeed hardtail is that it rewards a fun riding style, conserving energy you've generated from pumping, converting pumping energy into forward momentum well thanks to the lack of rear suspension, and once you're going at a decent speed downhill you can't add speed from pedalling because the gearing is too low, so having fun and not chasing times is the only way to ride it.
I will add that on most of our local singletrack, there is essentially no choice of line. There are a lot of tight corners and ups and downs that can't be pedalled, so pumping pays off!
Posted : 24/05/2024 2:36 pm
That's certainly a unique take.  Have you actually done that?
I haven't but this is the closest I could find on YT:
Posted : 24/05/2024 3:10 pm
You're absolutely right, this is why world cup downhill racers pedal out of the gate and don't stop until they reach the finish line.
Posted : 24/05/2024 3:12 pm
Maybe there’s a definitive answer on this thread?
https://singletrackworld.com/forum/topic/things-that-are-allegedly-science-but-are-self-evidently-magic/
They must be the fastest option otherwise someone in the XCO field would be taking advantage of running 27.5. When was the last time a top level xx race was won on 27.5.
Whether you prefer them or no is personal taste but there’s no denying they are quicker.
Posted : 24/05/2024 3:42 pm
jameso, J-R, J-R and 1 people reacted
I’m not being paid to win races, I’m riding my bikes for fun in my free time. So I shall continue to ride the way I find most fun – which will involve a lot of pumping!
This thread is about whether bigger wheels are faster than smaller wheels, not whether they are more fun. In general, they seem to be faster. Pumping might be fun, but if you want to go fast and have the choice between pedaling across a smooth line and taking a detour to stop pedaling and pump, pedaling will get you there faster.
Posted : 24/05/2024 3:43 pm
J-R and J-R reacted
If you want to primarily pedal and you are travelling over rough terrain then I don't think there's much question that the answer is the bigger the better.
However, the question wasn't why is 29 faster in XC racing.  29ers don't dominate all forms of mountain bike racing.
As I posted earlier, when people have made the effort to keep as much as possible the same and just change the wheel size the actual difference on the clock is marginal.  The difference in feel is more noticeable than any actual increase in speed which makes sense because there is no 'correct' wheel size.
You get roughly into the right range of sizes and then it's a question of compromises to achieve the performance characteristics you want.  Same as any other component on the bike.
Posted : 24/05/2024 3:51 pm
"Go to a pump track and compare your lap time pedaling with no pedaling."
If you're faster pedalling your doing something wrong.
Posted : 24/05/2024 3:57 pm
Most of my bikes are still 26ers, with a 27.5 XC hardtail and 29er commuter hardtail. On my regular training loop, the 27.5er is marginally faster on the road climb (about 20 seconds over 15 minutes) and my old 26" Anthem quite a bit faster on the descent (about 45 seconds over 7 minutes, all down to better braking over rough stuff). If I was racing, I'm sure that something like a 29er Anthem would knock 30 seconds or so off the overall time, those marginal gains matter if you are racing. I don't race so I'm not going to spend the money to upgrade to save 30 seconds.
Posted : 24/05/2024 4:06 pm
If you’re faster pedalling your doing something wrong
If not pedaling was faster, bikes wouldn't have chains.
Posted : 24/05/2024 4:10 pm
 5lab
if you're good at pumping its much much faster over some kinds of terrain (eg a pump track). On the flat it doesn't help you at all. most mountain bikers are terrible at pumping and can barely do a lap of a pump track without pedalling. if you're bad at pumping, then yeah, pedalling is quicker
If not pedaling was faster, bikes wouldn’t have chains.
like this?
Posted : 24/05/2024 4:17 pm
re, just watch the pump track races at crankworx
the amount of speed they produce on a chainless bike is insane... i don't think that if i i had a chain on the same course i would be anywhere near them
Posted : 24/05/2024 4:22 pm
Most of my bikes are still 26ers, with a 27.5 XC hardtail and 29er commuter hardtail. On my regular training loop, the 27.5er is marginally faster on the road climb (about 20 seconds over 15 minutes) and my old 26″ Anthem quite a bit faster on the descent (about 45 seconds over 7 minutes, all down to better braking over rough stuff). If I was racing, I’m sure that something like a 29er Anthem would knock 30 seconds or so off the overall time, those marginal gains matter if you are racing. I don’t race so I’m not going to spend the money to upgrade to save 30 seconds.
this is what I love about UK mountainbiking, on such a small island we have an amazing variety of terrains (and therefore variety in ideal bike)
Just from this paragraph we have found you have a local 20-25 minute loop with a single tarmac climb and single continuous descent. Your descending speed is only double your climb speed so unless you are climbing like a pro roadie that means the descent is technical enough to be a challenging technical affair and not fully a downhill seated pedal-fest.
Yet the limit to your descending speed is better rough terrain braking of a full suss - so presumably there are parts where you can go quite fast followed by bits where you need to slow, and the ability to brake later or better gives you the ability to hold a better speed on the faster bits.
7 minutes is a long time to be riding at your descending limit*, I wonder if the full suss is less fatiguing even with smaller wheels.
*there's only 2 ways to make a reasonable stab at comparing your descending speeds against yourself. Either do it as fast as you can, or do it as a pure no-pedal roll down.
Posted : 24/05/2024 4:25 pm
On the kind of trails I enjoy pedalling isn't usually an option.
If I was forced to go round in circles on an XC bike I'd quit riding.
Posted : 24/05/2024 4:33 pm
Have you not heard of a pump track?
Posted : 24/05/2024 4:35 pm
Yet the limit to your descending speed is better rough terrain braking of a full suss – so presumably there are parts where you can go quite fast followed by bits where you need to slow, and the ability to brake later or better gives you the ability to hold a better speed on the faster bits.
That is an excellent analysis. I am impressed. Yes, a very technical descent, some fast parts, some slow tight stuff, some sandy sections, some rock gardens, fast sections braking across roots into tight corners, etc. A 26er with a short wheelbase helps massively through the tight stuff. Being able to brake late into the corners really makes all the difference, that's where the hardtail just loses a fraction of time on each corner.
Posted : 24/05/2024 4:39 pm
On the kind of trails I enjoy pedalling isn’t usually an option.
If I was forced to go round in circles on an XC bike I’d quit riding.
I enjoy doing both (and actually my local is probably part way between the two).
Now if I was forced to ride round a flat XC loop on a long travel monster with soft DH tyres, that would make me quit riding.
Posted : 24/05/2024 4:42 pm
We're not talking about pump tracks, we're talking about riding normal trails. If you pedal into and out of a dip, the energy you gain going in is lost on the exit. If you avoid a smooth pedaling line to divert to something you can pump, you stop pedaling to pump it and you'll go slower than if you pedaled across the smooth line. The idea that a smaller wheel will make you go faster because you can pump out of dips is just silly unless you only want to ride around pump tracks. Bikes have chains and gears because pedaling is a much faster way to get nearly anywhere than pumping.
Posted : 24/05/2024 4:46 pm
Yes, a very technical descent, some fast parts, some slow tight stuff, some sandy sections, some rock gardens, fast sections braking across roots into tight corners, etc. A 26er with a short wheelbase helps massively through the tight stuff. Being able to brake late into the corners really makes all the difference, that’s where the hardtail just loses a fraction of time on each corner.
sounds amazing. if that was my local terrain I'd be doing 2 or 3 laps a night all summer. My bike collection is a Bird 29 hardtail and Santa cruz 5010 130/140 travel full suss. I'd take the santa cruz for I guess the same reason - short and agile by modern standards but probably long and ponderous if you are judging against a 26er anthem.
Posted : 24/05/2024 4:48 pm
If you avoid a smooth pedaling line to divert to something you can pump, you stop pedaling to pump it and you’ll go slower than if you pedaled across the smooth line.
Well, yes, if you ride like me and pinball around the trail looking for stuff to pump through then you will probably arrive at the bottom slower.
But at the same time if you divert away from the bumps and dips so you can keep pedaling then you'll also get to the bottom slower.
However, if you ride like a regular human and just take advantage of the natural undulations you'll probably end up going faster and/or use less energy as Neil Donoghue showed in the video I posted above.
But as someone else said above, most mountain bikers aren't great at pumping. Probably because they don't practice it enough.
If you can't do something then there is no doubt you are going to be faster if you stick to the thing you can do.  But in the long term, avoiding developing all your trail riding skills is going to lead to you being slower than someone who does take the time to develop a complete skillset.
And I think the reason bikes have chains and gears is because it's pretty much universally accepted that pumping up a hill or on a smooth road is pretty tough rather than because it is faster in absolutely every situation you will find yourself on a mountain bike.
Posted : 24/05/2024 4:57 pm
I was a late one to change from 26 to 29, but can't see me ever going back. But definitely understand that smaller wheels suit other folks more.
Posted : 24/05/2024 5:02 pm
I definitely get plenty of extra speed by pumping along an undulating trail compared to just seated pedalling. Allows you to be more ready to get the odd bit air too. Smaller bikes (with no suspension) are better at pumping, hence bmx racing on snall wheels.
Posted : 24/05/2024 5:09 pm
However, if you ride like a regular human and just take advantage of the natural undulations you’ll probably end up going faster and/or use less energy as Neil Donoghue showed in the video I posted above.
Sure, but the benefits from a smaller wheel on pumping are so insignificant that they make no difference on overall speed compared to the faster rolling of a bigger wheel. It's fine to enjoy pumping, but this thread is about which wheel size is faster. I think the evidence is that a 29er is slightly faster overall, but it will depend on the particular trail. Having the right tyres for the conditions and optimal tyre pressures will make more of a difference than the wheel size.
Posted : 24/05/2024 5:11 pm
"Bikes have chains and gears because pedaling is a much faster way to get nearly anywhere than pumping."
I've never seen any evidence of people pumping bikes before pedals or chains were fitted to bikes in the 19th century - what a silly statement, peak STW?!!
I (and much more talented riders than me) will continue to use a mix of pumping and pedalling (bear in mind that you pump corners as well as humps and dips) to ride fast/fun/smooth/controlled/etc down trails.
Sure, but it's a marginal gain. Nobody chooses their wheel size based on pumping, the main consideration is rolling resistance (i.e. pedaling efficiency) compared with packaging/geometry/bike handling. That's what this thread is about. 29" seems to be a good compromise, rolls well but not too unwieldy. The contribution of pumping over a multi-hour ride is so tiny that it's not a consideration for the overall speed.
Posted : 24/05/2024 5:27 pm
Sure the benefits are small but I suspect someone (think it was jameso) may have nailed it when they said it's less to do with the wheel size and more to do with the shorter wheelbase.
I'd argue that it's the same with the bigger wheels.  Yes, there is some improvement in roll over but these differences are eclipsed by the fact the wheelbase is also generally longer on bigger wheeled bikes along with the multitude of other geometry changes.
Wheel size is one small factor in terms of how fast a bike is but for some reason it has been held up as an example of an absolute.  Very few people would argue that a 2.25" tyre is faster than a 2.4" tyre. Or that 150mm of fork travel was faster than 140mm.  Most would say you pick what's right for you and the trails you ride.
I can't think of any other component where people are so adamant there is a 'right' answer to what is faster.
The contribution of pumping over a multi-hour ride is so tiny that it’s not a consideration for the overall speed.
Last time I was somewhere with a chairlift pumping was very much my preferred mode of propulsion.  Could have quite happily ditched my chain.
In fact. last time I was on a local ride I snapped my chain.  I just kept riding for another hour pushing up and pumping down.
How does a longer wheelbase make you faster? A larger wheel will have lower rolling resistance but a longer wheelbase won't change the efficiency of your pedaling. If it did, racers would have run much longer wheelbases.
I can’t think of any other component where people are so adamant there is a ‘right’ answer to what is faster.
It's not that there's a right answer, it's that there's a best compromise for most situations. If you look at F1 (literally, now), the Monaco GP is basically a race around an expensive gated community. If teams could design a car specifically for that circuit, it would be completely different to a car optimized for Silverstone or a car optimized for Monza. But they can't so they have to design a middle of the road car that works on fast circuits and slow circuits, and then they adjust is as best they can for each track (so, for Monaco, they run the biggest wings they can put on because it's such a slow circuit.)
It's the same with bikes, if you designed a bike for enduro racing in the Swiss Alps, it would be quite different from something optimized for XC racing in a jungle in Malaysia. But, you can't design a different bike for every situation, you have to choose one basic design that works reasonably well across the full range of contexts. It's not that 29ers are the "right" answer, it just seems like they are a good compromise. (Coming from someone who mostly still rides 26ers because the gains from a new bike would be so marginal that they would make no difference.)
Posted : 24/05/2024 5:49 pm
If pumping beats pedaling, why didn't you pump up the hills?
Posted : 24/05/2024 5:51 pm
