why don't fram...
[Closed] why don't frame manufacturers....
.... produce frames where you can remove all the cables with out having to undo mechs.
currently half-way through (it's late now, i've got nothing left to smoke and it seemed like a good idea when i started) cleaning my Alpine. removed the fork, wheels, brakes. but i can't fully remove the mechs and the associated cables without disconnecting them.
why don't frames come with the brake hose mounts for each cable mount instead of rings?
the worst is the (older) 456 that dosen't even have 'normal' brake hose mounts, but three rings on the top tube. it's a bit stupid having to disconnect the brake hoses in order to mount the brakes onto the frame.
... but why don't they follow the brake hose system for all cable mounts?
Posted : 21/03/2010 11:26 pm
Lapierre's do!! ๐Ÿ™‚
Sorry, thats probably not much help.
Posted : 21/03/2010 11:51 pm
see thats what happens when you run out of smoke- you start [i]cleaning[/i] your bike.
I nearly washed up today
Posted : 21/03/2010 11:54 pm
steady on, don't you have staff for that?
Posted : 21/03/2010 11:57 pm
grow my friend...grow. ๐Ÿ˜‰
Posted : 22/03/2010 12:00 am
no no no! i hadn't run out. i ran out whilst removing the cranks. both wheels were off and stripped naked, forks cleaned, brakes sparkly then just roach. oh well, our 'friend' is is coming tomorrow with a car-full.
i'll finish the bike tomorrow evening....
Posted : 22/03/2010 12:01 am
i do MrNutt, but i don't trust them to do the job properly.....
Posted : 22/03/2010 12:02 am
Im waiting on the postie myself- god bless the internet ๐Ÿ™‚
Posted : 22/03/2010 12:09 am
 5lab
nearly every bike i've had has cable mounts with a slit through the top for this exact purpose
Posted : 22/03/2010 12:45 am
