How does that work then?
because it washes fresh little bits of flint, thorns etc onto the road
Ive just asked the same question on another thread - im puzzled too
Makes the tyres sticky to. Wondered if it softens the compounds as well?
+1
'Cos when its wet the sharp things stick to the tyre for a couple of revolutions, by then they've started to dig in, then you've got a puncture on its way. When its dry the bits ping off or fall off before they get a chance to dig in.
and your tyres are wet so there is less friction resisting stuff poking through it.
perhaps.
Yes....
...yes...
...and yes.
When it's dry little bits of rubbish get blown to side of the road/into the hedges/verges by passing traffic - a decent amount of rain and it gets washed back out into a band at the edge of the road..... right where I'm riding - grrrrr ๐
water is a lubricant for rubber.
All wrong.
It's because it's [i]acid[/i] rain so it burns little holes through the tyre and/or tube.
HTH
Because puncture fairies prefer a cool, damp environment.
Hey oldgit - whats wrong with rubbing the grit off with the palm of your hand whilst riding along? Let me think though should that be infront of the fork crown, or behind?
Ordering some sprint wheels for 3PCX today...
Blimey I'm using ten ton tessies, Aksiums and landcruisers
Did those actually work OldGit? I ask as I have a nice skip find in my garage - an old Raleigh - which has those fitted and I'd not seen them before.
Pretty certain they helped. I mostly rode tubs and had very few punctures. Tyres/clinchers back then weren't as good and it wasn't unusual to have several punctures per ride.
The answer is wet sand Your hand gets covered if the sand is wet a tyre is no different
NEWSFLASH!
ALL PUNCTURES FOUND TO HAVE BEEN CAUSED BY WET SAND!!!
๐
I read it was reduced friction from rain on the tyre but where is the evidence?
Its just sods law, you get more punctures in the wet cos thats when its most unpleasant to spend time fixing them.
Most punctures on bikes (any type) occur in the rear wheel. This is because the front tyre picks up offending item and fires it into the rear tyre as it rotates. As stated, this happens more when wet as the front tyre is more likely to pick thorns etc up due to increase in stickiness.
I think it's generally accepted that flats are more prevalent in the wet as water acts as a lubricant. Try cutting a piece of rubber (old tyre, tube whatever) dry and wet, see which is easier.
As for wiping (whether by hand or some little device as above) it's an age old argument - [url= http://www.sheldonbrown.com/brandt/wiping.html ]not even Jobst and Sheldon can agree[/url].
Why does rain increase the risk of punctures on the road?
Does it? who says?
surely for thinks like wood and thorn splitters they are softer in the wet and less pointy?
Now this is more like it ๐
Hawthorn and Blackthorn thorns have a surface on them that when wet becomes very lubricated so will push through tyres easier. Just another suggestion.
I seem to recall reading in a cycling mag YEARS ago (so probably MBUK) that in the wet rubber loses is puncture resistance, but also that the reverse is true. The article quoted an un-named US tyre manufactuer who'd gotten into trouble some years previously by showing their tyres driving over a glass bottle repeatedly, grinding said bottle into many many sharp pieces of metal. They were ordered to stop running the ad as it was misleading due to the fact that it wasn't anything special about their tyre that enabled it to do so, it was the fact that the whole thing was done in bone dry conditions.
But as I said...it was in a cycling magazine...so it MUST have been true.
It is, as others said, all about reduced friction. On a dry tire, grit thorns etc, have to overcome the friction resistance of dry rubber as well as have the penetrative force to go through the tire. Water's a lubricant and we all know that a good lubricant makes getting into tight spots a lot easier. et voila'
Onzadog is the only one to get it right so far.
sez the expert
Wet sand does not cause punctures unless it has bits of shell Anything that gets wet will let dirt, sand anything stick to it. The secret to avoiding punctures is a decent tube as this the 'soul' of the tyre and find self cleaning tyres with a chevron or crescent pattern tend not to puncture If all else fails get the Halo Courier Berlin from billys.co.uk or Dutch Perfect tyres from cyclife as well as the puncture resistant tubes
They should have also got into trouble for continuity, was the bottle glass or metal!?
Tubeless - Don't notice ๐
I don't know what's worse - riding in the wet, or on the road...
couple of weeks ago i was doin a Danny mac style jump off the pavement (lol) and suddenly my tyre went all wibble wobbly and i landed crap (it was a ruddy carpet tack washed into the road....grrrr
