Seems like most of the gubbins is there already, and it would be good for hardtails at least. There's plenty of forks out there with travel adjust and lockout, so why not seatposts?
+1 a threshold setting would be cool.
Mine has about 2 inches of nice plush bounce.
It's a reverb.
I think it needs a service...
DrP
Bushing wear? One thing to move up and down 10-20 times in a ride, another thing to do that every minute.
+1 DrP
Feels quite unnerving tbh, not sure I'd want it as an actual feature.
thisisnotaspoon - Member
So how do the bushings in the forks and shocks cope?
I guess because we'd want rebound adjust on it, then Crane Creek owners would want a million setting to play with, Fox owners would wants Kashiwhatsitcalled and blue and red anno knobs and they'd end up costing £800 and weigh twice what they do now.
I've gone said it now haven't I?! someone from SRAM R&D (aka Marketing) will read this and next years reverb will come with UltraplushBoost dampers to take the trail buzz out of riding, but sadly they'll only be the metric 30.0 size so whilst riders of Cove's from 2009 to 2011 might rejoice, I'm afraid the early adopters of metric shock frames will need another frame.
In all fairness, the ones in the post are diminutive compared to the fork bushings...
I wonder how many psi would it take to make the post act as suspesion and what would happen if... containment of the post would be breached.
Buy a FS instead?
Nobeerinthefridge - Member
Buy a FS instead?
Good suggestion but I think it'll only work for the people who don't want a hardtail
I'm a bit confused, at what point do you want suspension for your ass? Going uphill is when I'm sat down on a bike, and generally, I flick my compression damping to max.
When I'm descending - I'm stood up.
Am I missing something about hardtail riders? Do you sit down when descending? What situation is the suspension you want in the post actually for?
My crank brothers dropper has 40mm of suspension travel 8)
Sus-seatposts are awesome for ****ing up your pedal stroke! They need some telescopic crank arms to really nail it though
I wanted a Flexstem so badly in 1993
My apologies, I meant people who don't want a full sus, or want a hardtail. I'm more than a little dyslexic unforts....
Why stop with the stem?
http://www.bikerumor.com/2012/08/28/found-baraminds-flexible-handlebar-smooths-a-rigid-bikes-rough-edges/
Rickon +1
What do you think this would actually improve shermer?.
I've got an old USE XCR on my '97 Lava Dome - it's great for taking trail buzz out of your backside/back on rough, pedally flat tracks. Can't say I've ever noticed it messing with my pedal stroke - at least not to the point where it's annoying/inefficient
That's a lot of comfort...
Sort of a pointless as a concept really isn't it?
Either you're the sort of person who rides like a sack of spuds, arse on seat at all times, or you want a dropper that allows you to move the seat a bit out of the way to move about on the bike when the terrain get a bit more challenging...
I can't really imagine who it would appeal to, doubtless it'll get made and marketed new and be a "revelation" to us all...
@cookeaa - not really. If you ride hardtail the extra comfort can be brilliant. If you also have to tow a child & trailer bike off-road on occasion, it's pretty much essential.
Got my old USE SX and a brooks Cambium on my Pine Mountain 1 - super comfy!
I got a lot of use out of a Cane Creek Thudbuster many years ago. But the point of that is that it [i]isn't[/i] a telescopic design, it's a forwards/backwards parallelogram.
For those unsure of the point: unless your trail is "just" up, followed by down, you do sit down a bit on non-smooth stuff. I had a very bad back at the time, and the Thudbuster was the difference between being able to ride and not.
As if the bloody things aren't troublesome enough! Brilliant, but troublesome.
Run bigger tyres with less air in.
Better yet..
a dropper posts the drops on button press....
if they can get little motors in seat tubes, why not use one to low the seat.
they should be called raiser posts not dropper posts....
Weight?
Suspension seatpost is quite a bit heavier than a normal seatpost
Dropper post is quite a bit heavier than a normal seatpost
Quite a bit + quite a bit = a lot
There you go. Reasoning with maths to prove it!
For much the same reason rear suspension designs where the bottom bracket moves relative to your saddle are considered a bit rubbish.
