swapping over an RC with a RCT3 damper from two 29er Pikes. Followed the manual and unscrewed damper from crown. Try to pull damper out and it seems still connected. Air pressure/vacuum holding it in? Any help would be appreciated
cheers
Chris
Posted : 31/01/2018 9:32 pm
bottom bolt (low speed adjuster...?) on leg
Posted : 31/01/2018 9:42 pm
(low speed) Rebound. Yep, you need to remove the foot nut.
Check here... http://www.epicbleedsolutions.com/blog/how-to-bleed-rockshox-charger-damper/
Posted : 31/01/2018 9:50 pm
Yup, that looks like the culprit!
a job for tomorrow now me thinks.
thanks all
Posted : 31/01/2018 10:01 pm
