Why can't I pa...
[Closed] Why can't I part my pistons?
Trying to fit new pads to my old Formula The One rear brake.
I can't push the pistons far enough apart to make space for the new pads and the disc.
Any ideas?
Posted : 11/08/2017 12:24 pm
Brakes are overfilled and need a bleed.
Posted : 11/08/2017 12:25 pm
you need to release some fluid from the system, undo the bleed at lever (making sure it's at the top) push the pistons in redo up the bleed valve and wipe away any fluid.
Posted : 11/08/2017 12:27 pm
Ace , just wanted to check if there was something I was missing before opening things up.
Ta
Posted : 11/08/2017 12:31 pm
Check for traces of brake fluid on the master cylinder, on the inside of the clamp. If you pushed hard enough, there is a possibility DOT fluid seeped around the reservoir bladder.
Posted : 11/08/2017 1:18 pm
All sorted now.
Managed to get the cheese-headed pad retaining bolt in and out one more time!
They are £25 from silverfish these days... 😯
New brakes...one day...
Posted : 11/08/2017 1:22 pm
^^^make your own shimano style split pin, it's only there to stop them falling out.
Posted : 11/08/2017 1:34 pm
