As the title says really - can anyone help?
classifieds? Not being facetious, should you need a 400lb 2.5" theres been one there for a long old while.
You get what you pay for.... go steel or get a good quality ti secondhand
I've never seen any quality or massive weight different with ti spring from using them extensively.. the first one I had I paid around £200 for and noticed barely any difference from the £100 offerings.
What are the cheaper one's meant to do?
Have seen a few cheap ones with corrosion in the ti (impurities) spring rates varying by up to 50lbs/inches from quoted.
Finish on ends of the end faces not square and look like they have been angle ground.
There is some rubbish about hence the steel being better value than cheap Ti.
Non of this is in refence to Tisprings I might add.
