What with the trends for slacker ha with frames like the mmmbop I was just wondering what the general feedback was now that they have been in the market for a while?
Do people see the benefit over say 68 ha bikes, or is there more to it?
My HT build will have a 66 HA with 140mm forks so I'll know myself soon enough 🙂
Slack Evil Sovereign here. Love it.
456SS with 150mm Z1sl's here. Lovely but climbs are nasty (or am I unfit?).
My Dialled Alpine was my intro to slack HTs and I've never looked back - too much fun. U-turns or lock down forks (ala Zocchis) are essential for 'proper' rides with climbs and everything.
It's wonderful, really wonderful.
It surely depends on your riding. My PA isn't considered slack at all nowadays but I wouldn't want anything slacker for the twisty SE riding I do on it, barges don't go round tight corners very well!
Couldn't tell you what the HA of my bike is. Don't really care very much about it either
blue pig here - it's brilliant.
the best thing about it is the head angle (about 67/68ish).
i should have bought a summer season - it turns out i don't really need/use the 140mm travel in my forks, it's just the head angle i like.
slack head angles with short travel forks please!
yes, Brant Richards is/was right.
Me. 456 SS with 'only' 105mm Marzocchis but still very slack. Feels lovely. Much better on fun, tech stuff than my old Soul but I'd not want to go on an all day epic on it. Most of my riding is 2 hour tech fests though so for that, slack = good.
made my mx comps feel more modern, on the mmmbop commuter
I chop and change between Pikes and Lyrics on my BFe - roughly 68 and 67 respectively, I would guess.
It's a little bit bargelike with the 160s on unless its proper steep (Alps, DH courses), at which point it's awesome. The Pikes are great in most UK conditions with a 50mm stem and widish bars.
Got an mmmbop with 160 on the front. Rides pretty much as I'd expected. Bit of a effort getting around uphill switchbacks. Not too bad on the tight twisty stuff. And feels great when it's fast, flowing and smooth. Taking it to Llandegla this weekend, reckon it'll be a great bike for a blast round there.
Slack head angle yes....
also like a steepish seat tube,which the blue pig has and this is what makes the blue pig good for me,over the front a bit for the climbs and corners..
as with other hardtails ive had seat tube angle werent too good on the liks of cove stiffee,bfe,p7,too much wibble wobble on the climbs for me,unless wind the forks which defeats the object and too much faffing.,
Carbon 456 with Lyrik U-Turns. Don't know how slack that is, but probably a bit? Rides ace. Usually run them at 140mm for general trail duties, 115mm for ling climbs, full beans for Peaks descents. No idea what the HA is at the various heights, but they don't cause much in the way of problems in use, so I can't see why I'd not want it as slack as it is.
Is 68 HA slack? I was thinking that most people who have slack HA bikes would be in the region of 66-67, i know its only 1 degree, but most trail type frames have a 68 HA anyway, and are often not called slack?
Where/when are you measuring the head angle at 66deg?
When it's leant against the garage wall, or when you're sat on it?
The two viral marketing kings go head to head.....
Popping up on a subject-related forum to pimp Ones' wares is hardly 'viral marketing'...
66deg static on a 160 bike is about 68.5deg at ride height. Which isn't steep, but isn't slack.
James has his Summer Season set up with 140mm Vans (they are i believe short for their length!) It looks and acts well slack. It is his xc bike, which also goes down the DH tracks (fast), does the jump trails (jump bikes are usually steep), he jumps pretty big and then .. and this really gets my goat he out climbs us. There is local climb very steep and loose at the top, needs some thinking, some traction, most fail, but he always gets up it!
It is a real lark on the steep downs. So Much for these slack HTs what really interests me is fat tyres.. 😯
ps
hi Brant 😀 -stacks of his kit in our house.
Hi Si - one bit of his kit.
Yes, now can Brant please lob 5deg off the seat angle as well on his bikes so that they work on talas/lockdown forks? You know theres something wrong when its easier to climb with 150mm of bob tastic marzocchis up front than it is with them locked down resulting in a seat angle steep enough to make a TTer wince.
Going to try a size smaller summer season with layback post next year, which is anoying as I like everything else about the bike.
si_progressivebikes - MemberIs 68 HA slack? I was thinking that most people who have slack HA bikes would be in the region of 66-67, i know its only 1 degree, but most trail type frames have a 68 HA anyway, and are often not called slack?
i've been saying this for months.
my pig is completely normal if you compare it with most 140mmish FS bikes, but for reasons that i can't understand, hardtails usually have steeper head angles - around 70ish.
i have no idea why.
the average hardtail rider/designer must like crashing i guess...
Different/same measuring techniques?
Sit on a hardtail and it gets steeper, sit on a full suser and it gets slacker/stays the same.
That and the kind of speeds where slack angles make sense your either not using your suspension on a hardtail because its smooth and fast, and therefore doesnt need to be so slack, or on a full susser, because theres no way a hardtail is going to go fast enough over rough ground to justify a DH-slack angle.
slack head angles don't just work at high speeds - they make sense for steep descents too.
(keeps the weight distribution 'nice' - stops you having to hang off the back to stop yourself pitching over the front).
if you want to ride a Ht down a steep trail, you could argue that you'd need a [i]slacker[/i] static head angle than an equivalent FS - cos as you correctly point out, a HT steepens under load...
Define 'steep'
its either going to be steep = fast in which case I'll take the chopper please
or steep and twisty in which case I'll take the sharper angled bike.
Rolling down a steep slope might be easier due to the longer front center on a slacker bike but how many DH runs are like that?
if it's steep and technical, i'd rather not be hanging off the back - buzzing my backside with the tyre.
i'd rather have a 'slack' head angle that allows me to remain centred on the bike and in better control...
in my experience, the fastest trails are not the steepest, steep usually means slow cos you'll be on the brakes (usually).
I measured static, cos that's the way I prefer. Actually I don't mind how they are measured as long as everyone does the same and understands what it means.
It's interesting, Brodie say the ti holeshit s slack with a 67.5 static ha, chumba say their 68 ha hard tail is neutral, when in reality there is not much between the two all things considered.
I couldn't understand why my 68.5 deg HA Marin with 140mm forks climbed so well, but then someone pointed out that the long wheelbase probably helped a lot!
Wasn't as much fun on tight (flattish) singletrack as my 70 deg Duster though.
It thought it was designed precisely so that you CAN climb on it with a big fork. If you are desperate to use your TALAS you can always get a different frame though 😉
I measured static, cos that's the way I prefer. Actually I don't mind how they are measured as long as everyone does the same and understands what it means.It's interesting, Brodie say the ti holeshit s slack with a 67.5 static ha, chumba say their 68 ha hard tail is neutral, when in reality there is not much between the two all things considered.
Our 160mm travel hardtails (Bagger288 and Troof) are listed as 67deg. But that's sagged.
Static, like you measured they are 64.7deg h/a.
That's quite slack, but perfectly rideable. A Blue Pig is about 65.5 deg static with a 140mm fork.
Mmmbop with u-turn 150mm Revelations here and a +10mm Hope Headset. Mmmm. Spends most of its down at 140mm effective but it does get jacked up sometimes when I just feel like chucking it at things. It replaced a Soul which by some people's definition is also slack but I wanted there to be no doubt 😆 Love it... Never yet felt that it's a disadvantage on either it or the full suss. Still got a steep angled rigid XC bike though.
Ragley (posh pig) Ti. Same as the Blue Pig. No more blues downhill, did my first drops on it and i was coming from a 5' FS trailbike......
Anyone got any idea of what the trail figures are with these slack head angles?
Ragley is circa 90mm at ride height.
Balfa Minuteman - 2002 slack head angled beefy hardtail. 66deg with 120mm forks! Longer fork than that and the seat angle got overly slack for climbing (70deg). The Balfa is a hooning weapon and hugely capable all around apart from the dinky seat tube and huge seatpost... also the problem was the weight, as things broke I built it heavier until 35lbs was just stoopid. So I bought a Whyte 19 which has very similar geometry... on paper... but the sky high bottom bracket makes it much more twitchy.
I'm still looking for something between the two - so a slack headangle, steep seat angle and low bottom bracket are high on the wish list!
With 30% sag, that steepens to 67.4deg at ride height - about the same as a Ragley Blue Pig.
Unless stated otherwise, should we assume that quoted head angles are static unsagged?
BFe with 140mm Pikes so I guess about 68 degrees? Feels well nice after being used to a 71 degree head angle for so long. Talking both unsagged here as far as I'm aware. Was thinking about going up to 160mm Lyriks but thinkin the extra 20mm probably won't make much difference.
68degs static is 70degs with 30% sag.
I used to own a rigid kona with a 70 ha, so not so much different to a 70 ha sagged bfe with pikes 🙂
No, I run a 68.3 degree head angle with 140mm forks on an old Sovereign.
I'm unconvinced by super slack HAs on hardtails- on a bouncer, it's great, but you do have a rear shock to soak it up. You don't on a hardtail, you "work the fork" (tm and c bikeradar 2008) and this needs a steeper head angle in my opinion. I don't think a steep head angle is for everyone, but I think a skilled rider will get more out of a slightly steeper HA.
I got a small chammy frame with Lyriks on. Gawd knows what the head angle is, prolly about 66-67? It's fab for steep stuff, DH stuff, bit wishywashy for pedally undulating techy trails, and a pig to climb with unless I wind the forks down. Never liked climbing much on a HT anyway, so the forks tend to stay at 160.
Trailstar must have been about 74 then, that's approaching a bmx HA 😕 I don't run 30% sag though, probably around 20 if that. Feels a bit "wallowy" to me if there's more than that.
Working the fork is a whole lot easier when it's not trying to throw you off the front.
I thought trail was set on the fork. Is 90mm a horiz measurement brant?
SpokesCycles - Member
"I'm unconvinced by super slack HAs on hardtails- on a bouncer, it's great, but you do have a rear shock to soak it up. You don't on a hardtail, you "work the fork" (tm and c bikeradar 2008) and this needs a steeper head angle in my opinion."
I don't get this at all. It's a lot [i]easier[/i] to work the fork on a slacker bike, whether it's a full suss or a hardtail. Or so I've found anyway. Could you explain what you mean any more?
Rake is set. Trail is a function of wheelsize, head angle and rake.
I just find it easier being a bit more over the front, on everything. Obviously, what I run isn't steep by any means. The superslack stuff like the 64.5 Ragleys just don't particularly light my fire.
When you corner on an ht you're over the front more, on a bouncer you're over the back more. A steeper ha helps with that.
Out of curiosity, have you spent much time on one?
Not enough on the super slack ones, no- hence not convinced rather than don't like. I have jacked mine back to 67 degrees with a bigger fork for a while and it didn't make any sense to me.
I can see the place for them, though. The 64 degree thing in t'alps would be exciting.
My Stiffee falls into the slack category at 66 with pikes set to 140. Feels fine for everything to me, although I do wind my forks down for climbs.
Do longer travel forks have less rake to reduce the decrease in trail as the head angle steepens as the fork compresses?
No.
I thought my Cove Handjob was pretty slack with a shortish fork on it, measured it at 67.5 with 115mm Rebas on there.
Handles like a dream on quick stuff but not as quick on tight stuff as my Genesis iO with a 70.5 HA (all static)
I'm tempted to try the 130mm Revs I've got on it, should see about 67 static, if I get hold of a pair of 2010 ones for my FS
Brant - How does a 456 SS compare to an mmmbop? I've got my summer season with 160mm 36 van r's and love the slackness but would be interested in trying an mmmbop if it's likely to be even slacker.
Mr whiles you may now call me a deviant again. I blame riding dh bikes...
"Not enough on the super slack ones, no- hence not convinced rather than don't like. I have jacked mine back to 67 degrees with a bigger fork for a while and it didn't make any sense to me. "
Yup, sure, but there's a big difference between just pouring extra fork into the front of a bike to slacken the HA, and designing a bike from the ground up for it.
I love my mmmBop's slack feel I'm running a FOX Talas 32 150mm, 15mm axle,taper steerer , just feels good.
Brant a quick question is the Nuke Proof Mega similar angles to the mmmBop?? I am thinking of buying one when they come out 😀
WTF BS is "working the fork"? please explain what you mean?It's a lot easier to work the fork on a slacker bike, whether it's a full suss or a hardtail.
FWIW my main bike is a 100mm forked hardtail with a 69deg HA and I use it for XC, DJ and DH.. I rode another 100mm hardtail with a 63deg HA for a few years for XC only alongside my main hardtail, super slack HA don't DJ too well so I stuck lighter parts on it. there's far more to a hardtails handling than just the HA.
The Mega is a 66deg head angle, so depending on how you set the rear up, is similar/slacker than the Ragley. But it is designed for going quite a lot faster 🙂
Sure is - the "I can get a slack head angle by putting a long fork on" thing is a bit daft.
I think, thought i haven't looked for a bit, that it's pretty similar h/a. However, mmmbop will end up with a slightly lower BB, steeper seat angle, though a similar kind of reach to the bars (shorter top tube, but steeper seat angle puts the bars in the same place, ish).
Commencal Ramones 2 on Pikes...67 I believe.
Slack and fun.
As far as I can tell, working the fork means biasing your weight forwards so that when you hit something the fork takes the brunt of the impact, whilst the back end 'skips' more.
Best tried with caution though. If you overdo it you end up being a lot more likely to go over the bars. Which is where the slack head angle thing comes in.
I think you need a bit of skill to do it properly IMO, probably best off weighting the fork for smaller roughness and unweighting/hopping over the big stuff where possible.
I built up a Blue Pig a few months back because after riding a Ragley Ti briefly, I thought it was intriguing. Back to back with a Hummer, the Cove felt sweet and balanced, but the Ragley - even with a not brilliant fork, I thought - was just, er, interesting.
The thing that works brilliantly with the Pig is the steeper seat tube. I've ridden several bikes with forks longer than intended - I've just taken a 150mm Rev off my RC405 because it felt wrong - but that's quite a different thing as while you might get a slack head angle, you also cant the seat backwards and screw up the weight distribution and BB height, most notable on climbs, but also generally. It's night and day compared to something that's designed from the ground up to work with a slack head angle and long-ish fork.
Anyway, yes, love the downhill stability, the climbability and the composure on steep, techy descents. I'm a very normal sort of rider, but the Pig makes me feel that I might actually, occasionally, be semi competent... works well in the snow too, harder to knock off line.
It does take a few rides to get used to and the Pig's a bit grumpy on meandery, flatter stuff, but ride one somewhere hilly and techy for a while and it all makes sense.
2007 Z1 RC2 forks, 150mm at full travel, set to give 1/3 sag and plenty of compression damping to keep them from being wallowy. Flick the ETA switch to climb though and its just becomes impossible, the only thing I can think of is that the seat angle must be becoming soo steep that it comes to a point where I'm trying to use the wrong muslces to turn the pedals, there jsut isn't any power!
Next summer I'll be on a 16" mmmbop or summer season with a layback poost to compensate.
Either that or a full susser 🙂
A few thoughts.
My Balfa has a 66deg head angle and 70deg seat angle with 120mm forks. I'd like the seat angle a little steeper as techy steep climbing is a nose of the saddle tricky affair.
My Whyte 19 has 67deg head angle and 71deg seat angle with 120mm forks. Climbs and rides okay but the high bottom bracket makes it unstable and a bit of a handfull in the nadgery fun stuff… but it does the miles better than the Balfa
I demo'd a Cotic Soda - 68 head angle and 70deg seat angle with 120mm forks. Bottom bracket was lower than the Whyte and the same as the Balfa, which made it feel great much of the time, but it didn't have the stability of the Balfa and Whyte when really pushed into the gnar… the bike had a tendency to "stall" when hitting things and felt like it didn't want to roll over them as effectively as the other two bikes. It also didn't recover as well from jumps and drops as if when being at full compresion I felt pitched over the front. Obviously this could be set up and other issues but I think the head angle had a lot to do with it. I like the feel of the head angle on the Whyte and Balfa as they suit my rather "blunt" and "bludgeoning" style of riding.
On all the above bikes I ended up running the saddle forward on the rails to make the bikes climb better - probably making the seat angle more like 72/73 deg. None of the above are perfect for what I want… if I had the cash I would get something made or at least keep trying some other frames. It's hard enough to keep up with the bits I break and wear out without buying lots of things to try 🙄
Brant… I've tried an 18 Ragley but it was too big and simply felt wrong for me. I would love to try a 16 or the 17 when they come out… perhaps when I decide I've had enough of the Whyte (or I break it again).
My full suss bike has a 65 head angle and 72 seat angle (saddle forward again) - it really suits my style of riding just fine.
Side note - I don't understand how people can use "sag" to modify the geometry for a longer fork. I tried it… and when I used a lot of sag I'd be bottoming the fork out all the time and eventually breaking it… but it also gave little benefit on the steep climbs as the fork is unweighted and hence at max extension anyway… so no point. Travel adjust forks also don't work for me as I always end up forgetting to change the travel 😈
71.5deg static seat angle on a 16in Ragley (with 140 forks). Half a degree steeper on an 18in, or half that on a 17in. Degree steeper on a 20in.
Yeah I understand this. Do you prefer to spin or pedal slowly on climbs?
Thanks for that, think I've seen a few sites where they describe fork offset as trail.Rake is set. Trail is a function of wheelsize, head angle and rake.
They are wrong then.
Fork offset can be called "offset" or "rake". But not trail. Trail is something else.
Oh - and regarding the ETA = no power... I'm sure several people reported a phenomena where lockdown forks make it feel like you're riding with the brakes on.
Ragleys are designed to climb without lock down. As I always forgot to take it off.
This might help some people here talking about the BFe:
http://www.cotic.co.uk/geek/#forks
"All angles are based on appropriately sagged forks"
BFe probably is about 68 degrees with 140mm Pikes WITH 30% sag.
Somewhere between the two, flat pedals but tend to sty and stick in the lowest gear possible and shift up when i run out of spin rather than a high gear and shift down when it becomes too hard.
Hey that is a great page on the cotic site Kelvin
Hmmmm mr spoon I guess I'm similar to you, but I was thinking that steep seat angles make it harder to get the power down, when you pedal slowly. I seem to need a layback post on all my bikes
We probably talk about HA in detail as it's easier to measure than trail and sus forks all have a similar rake, or it can't changed at least. Trail's the important bit tho.
Stem and weight dist variables can counter excess flip-flop but generally i like a HT that's slackened off to just at or before the point of having a noticable 'flip-flop' steering feel at ride height. Seems like a nice balance all-round and is as confident handling as a hardtail needs to be w/o feeling 'slow steering' etc. 80-90mm trail at ride height seems to be about there.
Is there a similar measurement for where your hands are, relative to the contact patch? That must change a lot between a xc frame w/ long stem & dh frame w/ stubby stem, more than the trail varies I'd imagine.
Certainly when falling down things, with lots of weight on your front wheel/rear wheel in the air, the relationship between contact patch and handlebar position is certainly important 🙂
I agree, I have the scars to prove it 😛
my 2003 hummmer has always had 130mm forks to slacken it 🙂
Spokescycles - the blue pig works well and balanced due to the seat angle,over the front
be honest ive never had a hardtail frame which has worked so well as this one ever!
[The Mega is a 66deg head angle, so depending on how you set the rear up, is similar/slacker than the Ragley. But it is designed for going quite a lot faster ] Thanks Brant, I like the feel/size etc of my mmmBop and to have a full sus similar would be great.
I've had a few hardtail with long travel SC Chameleon 140mm Pike, Orange P7 140mm Revelation and now the mmmBop 150mm Fox, all have been fun the Orange was really good and the Ragley is proving to be another good un.Just need to save up for a dropper seat post.
