ive seen the hope pro 2's but any others?
Superstar?
Superstar Components, Chris King, DT Swiss, Shimano. All worth a gander.
Oh and Maxle is a trade name for Sram's through axle systems - which is 20mm at the front and 10 or 12mm at the rear. The 15mm through axle is Fox's standard and as far as I know un-named. Not being smuggly pedantic but if you phone a shop to ask for a Maxle compatible front hub you'll probably either get a 20mm one or confusion from the shop saying Maxle don't do a 15mm.
oh, cheers mk1fan.i have RS rebas with a maxle front so it must be a 20mm then.
so can you get a 20mm to q/r convertable one? i didnt think shimano did a convertable one?
i thought rock shox have moved to 15mm for this season though?
well bought mine in 2009 so guess they will be 2008/09
Rock Shox are doing forks with qr, 15mm and Maxle this year.
Halo do one. 20mm/QR as standard but you can get 15mm adaptors as well.
I think the ones (except Shimano) I listed produce hubs that can be 'easily' switched between qr, 15mm and 20mm. Shimano's hubs need a bit more work on them to convert.
hope pro 2 is switchable too, shimano definately aren't
