which will result i...
[Closed] which will result in least pain .......(warning -cynic-al design mind in action)
[#2724743]
currently got pace rc29s on the front of my ragley TD-1
they are 440mm as per frame design .....but due to a tree interface at puffer the forks are on borrowed time !
im going to the alps in july for a backcountry week and i have a choice of this or my merida flx3000 with sids upfront - can only get a 2.1 tire in there at each end
was thinking of ragley with 80mm reba 29ers i have lying about (at 490 ac)- will climb like a dog but decend like a demon....added bonus of a 2.5 tire fitting up the back!
or do i have to go out and buy new rigid forks to go out there with till these fabled ragley/xlite ones come out ....
what ever the outcome ill probably offer the rebas up and make an informed decision based on experiance rather than numbers - unless of course brant says the headtube will come off , ill die and the world will end in nuclear war 😀
Posted : 06/05/2011 3:49 pm
[url= http://www.ragleybikes.com/ ]Tyre fit for TD-1[/url]
Have you had a 2.5 in there?
Posted : 06/05/2011 3:57 pm
goan slide the sliders right back .....
dave of the twinklyvariety has had a 2.5 schwalbe in his
i had a 2.5 in on a 26 inch tire before xmas ....
ive just thought of another possible but highly comical and stupid combo i could have.
sand man rigid fork with a 3.8 larry 😀
Posted : 06/05/2011 4:03 pm
what?
[img] [/img]like this ? lots of fun in the snow :o)
Posted : 06/05/2011 4:15 pm
I have that photo too from the snow pre sandman rear hub arriving . Cant see it being great in the alps how ever due to 100 mm rims
Posted : 06/05/2011 4:26 pm
"Design"? I see no design here. Back to school.
Oh and a week's riding a longer fork is IMO very unlikely to break the frame, unless you're already doing riding it wasn't designed for, which I doubt very much given you are asking the question.
Posted : 06/05/2011 4:53 pm
trail_rat - Member
...ive just thought of another possible but highly comical and stupid combo i could have.
I've been thinking the same. I was supposed to be taking this (completed) to Newcastleton this w/end, instead I stuffed myself riding the fixie round the "Puffer.
[url= http://farm6.static.flickr.com/5221/5657879034_018a708acf_b.jp g" target="_blank">http://farm6.static.flickr.com/5221/5657879034_018a708acf_b.jp g"/> [/img][/url]
Posted : 06/05/2011 8:31 pm
pop an extra shim in the reba to reduce the travel to 60-70mm and the axle to crown will be very similar to the pace when sagged but give you a bit of emergency boing
Posted : 06/05/2011 8:34 pm
Good plan tazzy !
You ridden that brian ? I prefer to ride my full fat - the ragley is just too light - rides like a penny farthing once at speed - good in snow though !
Posted : 06/05/2011 10:02 pm
The TD-1 is a great ride with the rigid fork; not convinced it will work with sus - but I look forward to hearing how you get on!
Posted : 06/05/2011 10:05 pm
I agree its el- rapido with rigid but steep alpine decents and heads down arse up = nae guid coupled with a rigid fork that is on he verge o snapping
Merida is nae better and i canny get gears on my gf rig !
The missus will be on a 100mm bike so some short rebas outfront would give us similar bikes
Posted : 06/05/2011 10:08 pm
I had a TD-1 for a while - it worked brilliantly with the shorter (26") fork - back was too long for me though; I'd love to try a TD-1 with the chainstays of my current Yelli Screamy.
Posted : 06/05/2011 10:11 pm
Gives it a planted feel though and lets it climb like a demon without wheeelyin under power 🙂
Depends what you want it to do i guess - doesnt manual over furrows well - doesnt need to though just pump em tis faster 🙂
Posted : 06/05/2011 10:14 pm
trail_rat - Member
...You ridden that brian ?
Not yet. Got to get my legs working properly again. 🙂
Should be "interesting" - my fork is 415mm AC so the head will be steeper.
It will be a similar angle to my Scandal when I was running it with my home-made fork and a fat wheel. I liked the steering on that.
If it doesn't work, I have other forks to put in it.
Posted : 07/05/2011 12:31 am
