Which valves for No...
[Closed] Which valves for NoTubes ZTR Flow?
Just ordered a ZTR flow on a Pro2 - I know I need some yellow rim tape and sealant but how are Flows drilled? Schrader or Presta? Do I need a rim reducer?
Would be greatfull if someone couild post a link to what I need - cheers
Posted : 14/08/2009 9:24 am
Get a flow rim strip, helps give the tyre a really solid seat and aids fitting/pumping up. Only 50g too.
To answer your question tho, drilled for presta :0)
Posted : 14/08/2009 9:27 am
no problems here running Maxxis UST tyres on the flow rims using just yellow tape. rim strip unnecessary IMO and Stans advise not to use it with UST tyres.
get a Stans Presta Olympic valve with a removable core. they're easy to find on the Stans website.
Posted : 14/08/2009 10:35 am
Or you can use the Mavic UST valvles.
Posted : 14/08/2009 10:53 am
