which tubeless seal...
[Closed] which tubeless sealant?
which sealant works well,, also have read reports of rim corrosion with some ,
Posted : 03/02/2010 8:46 am
Stan's is the usual winner in these polls
Posted : 03/02/2010 8:47 am
I've only used Halfords own orange muck and JRA Wheel Milk since I started playing with tubeless about 7 years ago.
The halfords stuff is ok, but I've found the wheel milk to be better. That said, Others may be better, but I find the JRA stuff adequate, and cheaper.
Posted : 03/02/2010 9:17 am
 devs
Joe's over Stan's every time. 3 tubeless bikes here, soon to be four.
Posted : 03/02/2010 9:38 am
[i]these polls [/i]
of which there seems to be one every day.
http://www.singletrackworld.com/forum/topic/poll-stans-or-other-milky-goodness
Posted : 03/02/2010 9:40 am
Indeed.
Stan's over Wheel Milk undoubtedly, I found the latter dried out within a couple of weeks. Not tried Joe's.
Stans turns into a clear liquid with latexy blobs floating around in it after a month or 2. It's really not that good!
Posted : 03/02/2010 9:43 am
 Hip
Started with Joe's then had a good deal on some Stan's... Have no problem with either, both do the job.
Posted : 03/02/2010 9:55 am
I used JRA's Wheel Milk for ages and it's fine. I found it ended up in a huge lump inside the tyre, so it's good for trail bikes where the priority is to avoid pinch-flats. If you have a risk of punctures like I do on the road - East Lothian has a lot of Hawthorn which is like needles - then you need your sealant to stay liquid. Stans does the job there better for me.
Not tried Joe's, Bontrager or the CaffeLatex foamy stuff which sounds good.
[url] http://www.tubelesswheels.com [/url]
Cheers, al.
Posted : 03/02/2010 11:46 am
Here's another thread too. It got a bit cheeky.
[url] http://www.singletrackworld.com/forum/topic/tubeless-sealants-caffe-latex [/url]
Cheers, al.
Posted : 03/02/2010 11:48 am
