thinking of trying 1x9 set up which is most popular toothed front ring, thoughts please.
Depends where you ride tbh 32-36 probably
32t if your riding is mostly technical off road and/or you're not too fit, 34 if you spend a lot of time riding on fire roads, tarmac and/or you are very fit. 36t if you really ought to be on a road bike but like to pretend at being a mountain biker.
and depends on cassette?
I have currently:
34T, 11-32 cassette on my Covert
36T, 11-34 cassette on my 456
It's initially difficult to get used to not having the escape of the granny ring but makes you a much stronger pedaller if you stick with it. I wouldn't go back to a double/triple setup on a mtb.
Couldnt decide so i got a 33t e13 one.
I used to use a 38t in the Peak district, I also had FUBAR'd knees though!
32t is a good compromise IMO, and has the added advantage of being the smallest you can get away with which is great for ground clearance, especially if you get a 32t specific chain device which most manufacturers make for that reason.
32 with a 12-34 at the back; get me up most things in Yorkshire and the Peaks but the Lakes would be an effort.
Have pretty much always run 34T/11-34 cassette on my 1 x n HTs.
slainte ๐ rob
thanks for replys will check my lbs tomor,see wot they got in shop. at moment got a 11,32 on back
What ring size depends opn how you ride and how steep your hills are. I used a 32T on a 1x9 years ago for XC riding around thetford forest. I think I had an 11-28 cassette. It's flat here though.
I've been using a 36 up front and it ain't been pleasant. Dropping to a 34 as an experiment but to be honest I'm thinking 32 will be the way to go.
There are so many variables that it's unanswerable. But FWIW, I ride 32t 11-36 which works well on tougher XC rides as it takes less out of my legs and I can spin fairly fast to get me to a good speed. If I had a bigger bike which I used for shorter rides (<3 hours) then I'd probably run a 36t and rely on stomping to get me up hills - just can't manage that pedalling on properly long or very fast with no stops (ie XC race) rides.
34 is too low for the fun bits but also too big for the climbs so keep a front mech and run a granny ring with a 36T if you want to ride everything.
32 tooth front with 11-36 back is fine for speed and climbs. The whole point of 1x is to get rid of the front mech. Considering people ride hills and downs with s/s 2:1, I'd think the range you get from 11-36 is wide enough for most eventualities for a fit rider, unless you absolutely need to pedal more when you are going 20mph+ (racing?).
[b](racing?)[/b]
No. making fast/long jumps cleanly
I find a 32 tooth way to small up front, whenever the fun begins your spinning out like a loon! It's a 36 for me.
I now ride 1:2 single speed 2:1 would be 2 revsd of the crank to one of the rear wheel. With that ratio you would never go anywhere.
To the OP quit 1x9 and ride SS then you won't weorry about your gear ratio's.
i run 36 11-28, road and fire climbs are mine but if its loose or a bit too steep it can slow things down abit. I might drop a tooth or two when i replace the ring next time.
I use a 34t on my DH bike (11-34t cassette as well) and it can be climbed on if I really want to put in some effort. 34-11 is more than hard enough for me on any DH tracks I've ridden.
You seem a bit confused. The 2:1 is refering to the number of teeth.
32:16=2:1
I have a very lightly used 33 Tooth e thirteen G ring in black for sale if your interested?
email is in profile
Ta
Dave
So these jumps then GW - how big are they? They must be 20 footers right? Chappeau.
