Which Helicoil/Thre...
[Closed] Which Helicoil/Thread Repair Kit?
[#5455632]
Need to sort out a stripped thread on a brake mount on some forks
Is it best to go with a proper Helicoil kit or are some of the cheaper ones just as good? Any recommendations?
Posted : 25/08/2013 9:32 pm
I use the dormer M6 and M5 ones and work very well and probably stronger than the standard alloy thread and stainless so wont seize the bolt
Posted : 25/08/2013 9:39 pm
I've just stripped the top 3-4 threads off mine by putting the short bolt in the long bolt hole.
Have threadlocked it in for now but would also be interested in a helicoil kit
Posted : 25/08/2013 9:41 pm
You wouldn't helicoil a 5/6 mm hole !,you'd go up a size just drill & tap the next size up ,5 to 6,6-8 etc ..
Posted : 25/08/2013 9:48 pm
Any helicoils should be fine, as for drilling and tapping to the next size up that's not possible on a fork mount because you would 1 seriously damage the integrity of your post mount and 2 an m8 bolt won't go through your caliper.
Posted : 26/08/2013 12:48 am
 sbob
reedspeed - Member
Why not?
A lot less hassle than having to possibly remachine a counterbore to accept a larger cap head bolt.
I think Armstrong were my preferred supplier, having fitted many thousands of inserts of all sizes and types.
Posted : 26/08/2013 4:41 am
The whole idea of a helicoil is that is keeps the same size bolt as before.
I just bought a cheap kit from eBay. Worked great.
Posted : 26/08/2013 8:45 am
I bought an M5 set off ebay (silverline I think) to fix a set of crossmax wheels with stripped disc mount. I've since bought m4, m6 and m8 sets and repaired stems/seatposts, a few post mount forks and even a rear end on a stumpjumper fst for a load of mates
best purchases I've made in a while, £40 total spend and probably recovered £500-600 worth of components and still have most of the kits left.
Posted : 26/08/2013 3:45 pm
Depends how confident & skilled you are,I know what i'd do !.
Posted : 27/08/2013 11:13 pm
What would you do?
Posted : 28/08/2013 12:15 am
Time-sert inserts. Superior to the standard helicoil.
Posted : 28/08/2013 12:54 am
 sbob
Ambrose - Member
What would you do?
Talk out of his arse, I'd wager. 🙂
Posted : 28/08/2013 1:07 am
