one of my friends needs a headset for a gt avalanche frame. the headtube has a 'shelf' part of the way in so im pretty sure it needs an integrated one.
will any integrated headset fit or does it need to be a specific one with regards to diameter??
Thanks for any help,
James
Headsets to fit GT Ava is usualy refered to as a "semi-integrated" or "Zero Stack" (ZS), not to be confused with "internal" type.
[url] http://www.chainreactioncycles.com/Models.aspx?ModelID=35225 [/url]
There a Cane Creek as an example.
I fitted one of these in an 08 1.0 frame. Tricky bit for me was finding one that mentioned an OD of 50mm
http://www.chainreactioncycles.com/Models.aspx?ModelID=15888
works well and spare bearings are available.
anyone know of any cheaper ones? he's trying to do this on a very small budget.
James
there is a prolight semi integrated one at crc for £17 with a 50od
3 types available the semi integrated one will fit
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=38692 ]http://www.chainreactioncycles.com/Models.aspx?ModelID=38692[/url]
This is cheapest I have found but out of stock at the moment. Superstar's Integrato has done wonders for mine (I know it's swearing to mention superstar on here) and the bearings are cane creek compatible.
Jay
