Which fork is this?
[Closed] Which fork is this?
I purchased a batch of stuff a while back with the intention of using some and selling on some bits. Completely forgot that a fork was part of that which I just came across in my garage. Unhelpfully the code on the fork is partially rubbed off, but it doesn't seem to be in the right format anyway.
Numpty question here but can you help me identify exactly what it is (It's a Rockshox Reba dual air, but the exact model would be helpful so I can get the right service manual etc)?
Fork 1 Fork 2Fork 3
Also is the damage around the bottom of the steerer a problem, or fine if I sand and give it a sand and a touch of paint?
Fork 4
Posted : 12/05/2021 9:52 pm
That looks like one I bought around 2008, although I don’t think mine had v mounts.
Posted : 12/05/2021 11:23 pm
If it were me, I'd just look at different user manuals for Dual Air forks and find one that matches. 2008 is probably a good start, the earlier models had fairly crudely painted graphics, then they changed to the anodized graphics.
Posted : 13/05/2021 1:05 am
2006 or 2007 Rockshox Reba xC from a Trek who used those blanking plugs and that hose guide.
Posted : 13/05/2021 8:44 am
There is only 1 number missing from the barcode, won't take that long to try all the combinations 😆.
I make it 3425144?9
Posted : 13/05/2021 8:57 am
Thanks everyone, very helpful.
I went on the trailhead part of the rockshox website and it wants a serial number in the format "Ex: 16T73323397"... Or am I looking in the wrong place?
Posted : 13/05/2021 9:51 am
The serial number looks to be on the rear of the fork on the right leg just under the dust seal.
Re the finish damage at the rear of the crown, that's consistent with stone chips but do make sure that any flaky corrosion is removed. Painting is a PITA because you have to mask off the stanchions, remove the dials etc and make sure that the surface is well prepared before priming and painting with suitably durable paints.
Posted : 13/05/2021 10:02 am
Looking at a similar age fork we have the 16T73323397 number is on the back of the crown where you have all the corrosion.
Posted : 13/05/2021 11:54 am
It could be earlier, it has 04/05 ish graphics. You'll get no joy from the Trailhead app on forks that old.
Posted : 13/05/2021 12:21 pm
I have a Reba Race from 2005. It has white painted graphics. I'm pretty sure the OP's fork is slightly later. Whether there are any functional differences in the service manuals is a different question.
Posted : 13/05/2021 12:40 pm
The pintrest pic suggests its a 2005, but other pics of 2005 look differnt on the graphics. And thanks on that re Trailhead...
Posted : 13/05/2021 1:27 pm
decals would suggest it's more 2006/07
see review here: https://www.bikeradar.com/reviews/components/forks/suspension-forks/rockshox-reba-race-review-2/
The 2004/05 had solid writing in a different font, and the rockshox logo's were in colour.
same internals though, pretty much.
Posted : 14/05/2021 10:44 am
As for servicing and setup, it'll be identical to other RS forks of that era. Which is fairly similar to the current ones unless you are ripping the damper apart.
Posted : 14/05/2021 3:39 pm
It's a Reba Race, I have that exact fork on the front of my daughter's bike, IIRC the 08 Reba manuals seemed about right.
Posted : 15/05/2021 12:14 am
Cheers, I had flicked through the manuals and decided the 05-08 Reba's must be the right one so thanks for the confirmation. It seems to have quite a nice motion to it, any advice @cookeaa for looking after it. Think I need give it a service and who knows when it was last done! Any ideas on best place to get seals etc.
Posted : 15/05/2021 12:44 am
When I got mine it seemed pretty much knarped, it looked like it had never been maintained, the stanchions are thoroughly worn
The best thing you can do is pull it all apart, clean thoroughly and re-oil. TBH the stanchion wear has little effect on the fork's performance...
I used 2.5wt to try and speed up the damping a shade for a lighter rider, and you can play endlessly with +/- air spring to adjust sensitivity/ride/sag. It didn't come the the remote and she'd never be too bothered about playing with compression so I just left it be...
eBay for seals..
Posted : 16/05/2021 7:45 pm
