As above, please suggest one that works for longer than 3 months and doesn't strip valve threads as it's so wonky....
I like my leznye control drive. being able to control the flow rate is useful.
As above, please suggest one that works for longer than 3 months and doesn’t strip valve threads as it’s so wonky….
Valves don't strip threads, that's the domain of the gibbon fisted... 🙂
Innovations microflate nano. No screw thread. Press on. Unscrew co2 slightly. Hold until empty. Remove. Never had an issue. Tiny. Keep one in multiple packs.
the gibbon fisted
Ah, you met my 16 year old who uses this device then?
Lezyne Control Drive, without question. Push on, twiddle knob, inflate, pull off. (peel CO2 cylinder from hand because you forgot to wear gloves!)
Next.
Never had a problem with the Specialized Air Tool Cpro2 Microblast. Push on, pull off. Opens and closes on the push pull. No knob to twiddle. Lidl had one in a couple of weeks ago at £4.99 which looked a bit more industrial but was alot cheaper.
Tis a lovely thing. Source some Lezyne 25g CO2 from Evans (5 for £19).
