where can i get a s...
[Closed] where can i get a sram front mech spacer?
bought sram front mech off the classifieds a while ago but it came minus the spacer that takes it down to correct diameter for seat tube.
its a moots YBB so 31.8, and the mech has 34.9 stamped on inside of it. so basically its the spacer between those 2 sizes.
ive got another sram (x-gen?) mech (broken unfortunately) and would use that spacer, but its not compatible as it has a sort of triangular lug built into it, whereas the one i want is completely smooth.
also tried packing it with the rubber strip you use between bike lights and bars, but that worked like a bag of sh*t ๐Ÿ™
anyone know where i can source the right jobby?
thanks ๐Ÿ™‚
Posted : 11/06/2009 2:54 pm
its an X9 btw. looked around and i can only see x-gen adaptors, so maybe looks like they dont do them, and it has to be the exact size ๐Ÿ™
Posted : 11/06/2009 4:08 pm
Which SRAM front mech is it? If it's an X9 mech, both the top pull and conventional versions come in 31.8 or 34.9, I think, so there is no spacer as you need to buy the right size.
Posted : 11/06/2009 4:09 pm
yeah looking like i messed up then and should have made sure it was a dedicated 31.8 :-/
ah well............back to the classifieds ๐Ÿ™‚
Posted : 11/06/2009 4:15 pm
this is my mech. its a top pull as the cable comes in at the top i take it. but is it top swing or bottom swing?
Posted : 11/06/2009 9:27 pm
I made a front mech shim a few years ago using a USE seatpost shim; they do one that is OD34.9 and ID31.6?
Posted : 11/06/2009 9:39 pm
