Where are we buying...
Where are we buying our SS stuff from these days?
Having dropped my chain about 4/5 times on today's ride (and also several other times on the last few occasions I've ridden the SS HT), I've accepted the need for a new chainring and rear cog. (It's not a chain tension issue).
I've usually used On One / PX, but they seem to have stopped doing SS stuff.
So where are people getting theirs?
Ideally steel chainring (non NW - unless people can convince me NW has a benefit for SS?). And a wide-based cog for an HG freehub.
Ta.
Posted : 03/11/2024 4:19 pm
Oh, it's a singlespeed thread. I was expecting another Pro HTLR tyre thread.
Posted : 03/11/2024 4:22 pm
oceanskipper, thenorthwind, hardtailonly and 17 people reacted
Surly do a stainless steel singlespeed chainring - Google suggests Bikemonger sell them. Gusset do a wide-base SS sprocket.
Posted : 03/11/2024 4:31 pm
Bike Monger are very good.
Note that Surly sprockets don't work with 9sp chains
I really just came here to say the same place we are getting the Hitler tyres from but I've been beaten to it
Posted : 03/11/2024 4:34 pm
NW helps for a sprung SS setup in the same way it does for a geared setup, why wouldn't you choose one?
Posted : 03/11/2024 4:35 pm
“Ideally steel chainring (non NW – unless people can convince me NW has a benefit for SS?).”
I can’t see any downside to using a NW chainring for SS and obviously the upside is it’ll keep the chain on better when it’s worn and needs tensioning. Not sure what/where to suggest because there’s so many types of fixings for chainrings nowadays - I’ve got the stock Shimano composite (steel teeth) one on my SS on Shimano cranks.
Posted : 03/11/2024 4:44 pm
GeForceJunkyFull Member
NW helps for a sprung SS setup in the same way it does for a geared setup, why wouldn’t you choose one?
Thanks. Makes sense. But I've a BB mounted fixed tensioner, so assume NW won't have any benefits? Also, tend to just run an 8-sp chain, so too wide for NW to be effective?
Posted : 03/11/2024 4:45 pm
@andrewh … I didn’t know that about Surly sprockets. I’ve been getting some drivetrain noise that I cannot pin down a cause but I’ve recently changed the chain on my bike using a Surly sprocket to guess what … a nine speed SRAM chain!
Edit … Bikemonger list them being 9 speed compatible … hmm.
@hardtailonly I’m currently running a Surly sprocket and Surly chainring on my fixie both procured from Bikemonger - they are quick to despatch and super helpful.
Posted : 03/11/2024 4:52 pm
I bought one because it said 9sp compatible but I couldn't get it to work properly with an XTR 9 so chain, fine in the work stand but jumpy under load.  Excellent service from Bike Monger sorting a replacement. IIRC hilst it's says 9sp the quoted width is very slightly different to Shimano's quoted width for 9sp.
I've got a fancy Boone one now and it's brilliant (that does work with 9sp and comes in many more sizes, but it's not cheap!)
Posted : 03/11/2024 5:35 pm
Gusset Double Six cogs are good, I have used them for years. Very wide base at around 7mm I think.
As for chainring, what BCD and 4 or 5 chainring bolts?
Posted : 03/11/2024 8:55 pm
anono and anono reacted
 Del
haven't had any trouble with surly cogs for years with PC979 and 959 (IIRC).
have been running NW shimano rings up front for the past 6 years. the chain drops off the top, not the bottom, so not sure what difference the tensioning mechanism makes?
Posted : 03/11/2024 9:35 pm
In theory a fixed system should not allow it to drop if well adjusted, but I bet the amount of frame flex allows it to fall off.
Posted : 03/11/2024 9:40 pm
I can’t see any major downside to having half the teeth on a singlespeed chainring be thicker and stronger than normal! I’m not exactly putting in the miles on the singlespeed at the moment but I think mine has been on NW for best part of a decade.
If you’re happy with round rings and are currently in 104bcd I’d say the easy answer is the sram steel N/Ws that can be had for under 20 quid. Raceface do a steel ring for cinch cranks.
If it’s oval- whatever fits your cranks. Or if you can take direct mount and are feeling flush, the WTC Camo stainless ring?
Posted : 03/11/2024 9:43 pm
Try velosolo.  https://www.velosolo.co.uk/shop.html
I think some of the stock is running out but certainly worth a look.
And of course sjs cycles.
Posted : 03/11/2024 10:12 pm
I just replaced the rear wheel on my SS with one from https://www.santafixie.co.uk/
Posted : 04/11/2024 6:08 pm
Shimano actually make decent singlespeed stuff.
https://winstanleysbikes.co.uk/components/drivetrain/single-speed-parts
Posted : 04/11/2024 9:09 pm
Expensive, yes. But I loved my one that was on my old Inbred. It did thousands of miles without skipping a beat, and had a lovely freewheel sound. Pick-up was also very nice. Obviously you need a singlespeed wheel though.
https://www.stradawheels.co.uk/product/white-industries-eno-freewheel/
freewheel-montage
Posted : 04/11/2024 9:17 pm
