When to change brak...
[Closed] When to change brake pads?
New ones have about 3mm of 'pad' old ones have about 1mm. Is it time to change or can I wait a bit?
PS cheap mechanical brakes on a bike used by a newbie for XC rides. Pads are about 350 miles 'old' if any of that has any relevance
Posted : 05/06/2013 1:32 pm
I'd be looking to change them or, at the very least, carry a spare pair. If the pads go completely you risk damaging your rotors..
Posted : 05/06/2013 1:39 pm
 Muke
When you see sparks they need changing ๐Ÿ˜‰
Posted : 05/06/2013 1:40 pm
 D0NK
when you hear the spring get mangled against the discs is a good time.
You do always care spare pads don't you?
of the correct type?
for the bike you are actually riding now?
jolly good.
Posted : 05/06/2013 1:43 pm
I always carry a spare set & sometimes they're even the right ones for the bike I'm riding !
Either way I rarely change them till they're on the metal anyway,unless I've got an epic or event to do..Rotors are pretty tough & can stand a bit of metal on metal now 'n again.....
Posted : 05/06/2013 1:48 pm
You get a feel for how long they last... I run mine pretty close because I'm a skinflint, 1mm is still a third of their life in my book. But you lose all the margin for error, it's a bit like deciding to go to the bathroom because your feet are wet :mrgreen:
Posted : 05/06/2013 2:12 pm
At 1mm I'd make sure I have spare set to hand and check after each ride. Perfectly fine to ride with 1mm of pad
Posted : 05/06/2013 2:34 pm
When you find yourself 20 foot deep in the bushes at the apex of a DH corner, thats when you change them.
Posted : 05/06/2013 3:11 pm
As above - use but check after or before every ride and carry spares.
It'll be fiiiiine.
Posted : 05/06/2013 3:51 pm
Preferably before you wear through the backing plate of the pad and have the pistons contacting the rotor. I have seen this, how on earth the chap didn't realise the horrible noise when braking was a bad thing I have no idea.
Posted : 05/06/2013 4:14 pm
 JoeG
๐Ÿ˜ฏ
YJCMTSU! ๐Ÿ˜†
Posted : 06/06/2013 5:03 am
Let the backing plate clean your rotor and then bung some new ones In
Posted : 06/06/2013 7:39 am
I discovered at the Dudes Enduro last year that Formula The Ones with superstar pads have first class backing-plate braking performance. Apparently Hope don't perform as well when you get down to the metal-on-metal.
Posted : 06/06/2013 9:37 am
I was expecting some comments on how running them until they are to thin leads to a breakdown of the 'pad' and a sudden collapse of braking ability.
However, it sounds like I will carry on for now and see what happens. I have ordered two new sets and (based on comments above) will stick one set in my puncture repair kit so that they are on hand when I am out on the bike
Posted : 06/06/2013 9:44 am
I hardly use mine so never changed them. However, I have 'heard' that there is a little bit that pokes out of the spring retainer, this makes a ringing sound when it gets down to this, that signals it's time to change the pads at your next opportunity, apparently...
Posted : 06/06/2013 11:01 am
