Wheelbuilders - int...
[Closed] Wheelbuilders - interlace third cross or not (straight pull spokes)?
I'm lacing up a new wheelset for the first time (DT Swiss 350/481/511/Competition straight pull). Would any experienced wheelbuilders care to share their opinion of whether to interlace the third cross in the 3-cross lacing pattern (ie. under/under/over or over/over/under) or just go over-over-over/under-under-under with the spokes not touching at the third cross?
I wouldn't have thought straight pull spokes are any different to J-bend in this regard, and everything I read for J-bend says to interlace at the third cross, but my old Spank factory-built straight pull wheelset doesn't interlace. Looking at photos of DT Swiss prebuilt wheelsets it's hard to tell if they do interlace.
Advantages, disadvantages, does it really matter?
Posted : 13/10/2017 2:53 pm
I'm no wheel builder, but i'd have thought that the 'over 2 spokes, under 1 spoke' is the best way.
Crossing spokes too soon after they exit the hub flange would cause unnecessary deformation?
Never laced a straight pull tho'
So might be best to ignore me.
Posted : 13/10/2017 2:58 pm
2 under, 1 over for 3x - I build mine trailing spokes heads-out and then the leading spokes heads out, which are the ones that cross.
Posted : 13/10/2017 3:03 pm
I think scientifically it doesn't matter much - there's a theory that the interlacing slightly balances out the compression cycle of the spoke, and there's the other theory that interlacing means a snapped spoke doesn't flail around so much.
On big wheels I usually interlace, on small wheels I don't bother.
Posted : 13/10/2017 3:25 pm
A friend just told me that his DT Swiss wheelset came built interlaced, so that's what I'll do. Thanks everyone.
Posted : 13/10/2017 7:08 pm
