Wheel truing stands
[Closed] Wheel truing stands
[#6451636]
Anyone know of a decent truing stand for under £80? Or are the cheap ones all crap? Got a £50 voucher for CRC for my birthday and quite fancy buying something useful that I normally wouldn't buy.
It doesn't have to be from CRC as I will use the voucher for something else if need be.
I currently use the DIY method of a zip tie to the frame so no need to explain those methods to me.
Posted : 01/09/2014 11:30 am
I have got one of these Jobsworth stands, very solid great value for money its a very obvious copy of a park model but without the price tag.
http://www.planetx.co.uk/i/q/TOJWWTS/jobsworth-wheel-truing-workshop-standard
Posted : 01/09/2014 12:05 pm
The Minoura one isn't bad but it's a bit wobbly and I reached the limits of what it could do rather quickly.
I know it's no good with your voucher but I got a used Park TS 2 off eBay and added the 2.2 jaw kit. But I do a fair amount of wheel truing and building so it was worth it.
I have that ^ Jobsworth one, works a treat. I believe, but can't prove, that the Park versions adapters also fit it. Bang on your budget too.
Posted : 01/09/2014 12:38 pm
Cheers chaps,
That Jobsworth one does look good. Shame its not on CRC for my voucher though.
Posted : 01/09/2014 12:48 pm
The Minoura one is fine. It can be a bit fiddly getting it centred correctly but you can just flip the wheel over occasionally and/or use a dishing tool (my stand came with one).
Posted : 01/09/2014 12:51 pm
 bish
Does that jobsworth stand fit a 29" wheel with the tyre still on?
Posted : 01/09/2014 5:28 pm
I'd take whatever cash you can garner from present givers and pony up the rest to get the park ts 2.2 stand its solid kit that will last a lifetime
Posted : 01/09/2014 6:15 pm
 kcal
There's a Feedback / Ultimate one, which is 'OK" - the adjustment knurls aren't tight / spot on though.
£79.99 🙂
http://www.chainreactioncycles.com/feedback-truing-station/rp-prod12977
Posted : 01/09/2014 6:40 pm
Yes bish the Jobsworth will fit a 29er with the tyre still on.
Posted : 05/09/2014 11:28 pm
Job for a rainy day, but build one...[url= https://nuxx.net/blog/2009/04/26/wheelpro-truing-stand/ ]DIY[/url]...the one in the pic still needs its alignment tools making
Then spend your voucher on something shiny
Posted : 06/09/2014 6:00 am
+1 for the wheelpro stand. It's the second best one I've used. Assuming you have the tools (ideally you want a router and/or a pillar drill) it's cheap to make. Far more solid than anything you can buy for less than £300.
The best one I've used was a huge cast iron one in Thomas' cycles in Bury St Edmunds. Alas both shop and wheel stand are gone.
Posted : 06/09/2014 6:54 am
