Whats your resting ...
[Closed] Whats your resting heart rate?
Normal resting is 38, 44 yrs old, max is 187. Have an asthma check up every yr and if get diff nurse have to explain as they get concerned re low HR. Can only compare resting HR with yourself on a regular basis as everyone is different. As said recovery rate is a better indication of fitness, loads of stuff on the web about how to check that.
Posted : 17/12/2014 1:28 pm
age 63 and RHR is 12
what do I win?
Posted : 17/12/2014 1:43 pm
Age 42, resting heart rate of 33.
Posted : 17/12/2014 1:44 pm
Age 45, 47 BPM
Posted : 17/12/2014 1:46 pm
When I used to run a lot mine would drop about 40bpm in the first 60 seconds after stopping.
You're OK. If it's under 12 after 2 minutes, you're going to die.
Posted : 17/12/2014 1:52 pm
48 and it's 55. Used to be 39, it's not a great indicator of fitness but I was a lot fitter when it was 39....
Posted : 17/12/2014 2:11 pm
I've had 2 coffees this morning and my lunch in the last half hour. Is that why its 85 and I'm only 36..... 😯
Posted : 17/12/2014 2:32 pm
Onzadog - Member
Training for an ironman last year it was 37bpm at best. Not bad for a 39 year old. No idea what it is now.
POSTED 2 HOURS AGO # REPORT-POST
Seems people think the lower the better? So many athletes on here isn't there... 🙄
Posted : 17/12/2014 2:52 pm
42 Years old, RHR averages 42 (Tracked every day)
I remember back at 23, I had a RHR of 44 and a return to resting from 80% of Maximal of about 70 seconds 😯
I haven't checked rate of return lately but I bet its nowhere near as good as it was back then 🙁
Posted : 17/12/2014 2:57 pm
Your resting heart rate is simply that ,your heart rate at rest .
Heart Rate Recovery (HRR)is a more useful index of cardiovascular fitness.
Posted : 17/12/2014 3:01 pm
41 bpm right now, at the tail-end of a cold with a few cups of tea drunk today. 43 years old.
Ton's right though - it's the recovery after exertion bit that's really important/willy-waving material.
Posted : 17/12/2014 3:07 pm
brakes - Member
what do I win?
12!
Posted : 17/12/2014 3:09 pm
 wors
Mine is 56 and I'm fit as f&*k 😆
As above recovery and vo2 max are a good indicator of fitness.
Posted : 17/12/2014 3:19 pm
brakes - Member
what do I win?
12!
it's dropped to 8 now as the amphetamines have worn off...
Posted : 17/12/2014 3:25 pm
37 and 52bpm
Posted : 17/12/2014 5:38 pm
Age 49. Resting heart rate 45. Been off the bike since early Oct due to shoulder injury but had RHR of <50 all my life whether I'm fat/thin or fit/unfit! Bad genetics for some stuff, cancer x 2, good for RHR which I always think is odd.
Posted : 17/12/2014 6:45 pm
You're OK
Thanks wrecker, OK will do me. I've advised the fridge Stasi accordingly.
Posted : 17/12/2014 6:53 pm
I used to know an incredibly fit woman whose RHR was 90. My brother is much fitter than me but his RHR is 20 higher (he got my father's whizzy heart, I got my mother's plodder). It only means anything if it changes for you.
Posted : 17/12/2014 7:14 pm
I'm 37, resting rate is 42, measured with a hrm whilst asleep. Rises to circa 46 when sitting on sofa.
Posted : 17/12/2014 8:40 pm
35yrs 40bpm, not at the moment though cos I'm ill so it's 55.
Posted : 17/12/2014 8:47 pm
Age 35. RHR anywhere between 43 and 55, depending on time of year.
Was close to 70 about 4 or 5 years ago when I was drinking and smoking.
Posted : 17/12/2014 9:11 pm
44yo and 45 resting heart rate.
Posted : 17/12/2014 9:13 pm
Age 18, RHR 42, have had it at ~215 doing sprintervals in the gym though..
Posted : 17/12/2014 9:47 pm
 Haze
42 years old, counted pulse rate currently says 58 but Garmin says 88.
Using the HRM it's normally around 70, not really sure how much I trust it though given the above.
Posted : 17/12/2014 10:01 pm
About 64, no idea what that means
Posted : 17/12/2014 11:38 pm
I don't know but might measure it in a sec as I'm curious now. When I went to the doctors in August, he did say "are you some kind of athlete?" Which was odd as I certainly don't resemble one.
"Yes, I'm a Mtb racer" I said suavely without a hint of irony 😀
"Ah, that explains it!" He said but never elaborated 😕
Posted : 17/12/2014 11:44 pm
Not sure what is is now age 38 but 5 years ago it was measured on a 24 hour each at 42. Definitely doesn't equal fitness and as I have AF episodes it also doesn't equal healthy heart.
Posted : 18/12/2014 12:20 am
Age 44, RHR ~48 (52 at the moment, but not totally restiung). It used to be ~42 when I was fitter, and occasionally under 40 - the lowest I ever measured was 38. So to some extent lower does mean fitter - I'm sure that normal unfit people aren't even as low as 48 unless they've got something wrong with them - though it's a pretty rubbish way of comparing fitness between different people.
Posted : 18/12/2014 1:04 am
28 year old Resting heart Rate of 54. Blood pressure was 160/107 though! Check bp every morning before taking my ramipril.
Posted : 18/12/2014 9:48 am
Low enough to set the alarms off when I have a GA. I think that's probably sub 50 but IANAA. (Anaesthetist) 🙂
There is an inverse relationship between BP and HR. Greater BP requires fewer beats to push the blood round.
Posted : 18/12/2014 10:04 am
Comparing resting heart rates of different people does not mean a lot as there is so much genetic variation.
It is true that for a given individual the fitter they are then the lower there resting heart rate. However you could take two people who do not exercise, one has resting rate of 75 and the other 55. If they both exercise then there resting rate will drop. The first may drop to 50 and the other 65 but the one with 65 still out performs the other.
Hence comparing resting heart rates between individuals becomes irrelevant. Can still be very useful on an individual bases, especially if you start using heart rate variability to guild tanning.
Posted : 18/12/2014 11:21 am
[quote=paul4stones ]Low enough to set the alarms off when I have a GA. I think that's probably sub 50 but IANAA. (Anaesthetist)
Didn't even get any comments about mine when I recently had one, and it was certainly consistently <50 when I looked. I presume they'd got their baseline from when I went in and knew it was normal for me. Though I did get a comment that my BP was nice and low. I'm less than convinced there is the relationship you suggest even in a single individual - if I got unfit and my RHR a lot higher, would my BP drop below normal levels to compensate?
Posted : 18/12/2014 6:36 pm
Mines about 58, as in resting for a bit midday at work. I thought it was higher, well it was when I checked it randomly as in about 76 and over 90 at the hospital.
I find these variations interesting. Treadmill testing took almost 20 minutes to get my HR to reach 100.
Testing on the turbo was a revelation as they were looking for the speed of recovery from near max, mine was very good which is great as I've always had high resting rates which worried me.
Conversely my wife who has been ill since her teens is slim and healthy looking and with a resting rate in the low 40's, but as said she is ill enough not to be able to get insurance.
You need facts and figures, dead people have very low RHR's
Posted : 18/12/2014 7:53 pm
I whacked my HRM on, fell asleep on the sofa watching Family Guy whilst waiting for it to settle, woke up, switched the Garmin on, and it was 44.
Isn't it supposed to be measured 10mins after you wake up in the morning to get a true reading?
Posted : 18/12/2014 8:41 pm
Dunno, running round like a looney at 5am and quaffing coffee?
Posted : 18/12/2014 9:03 pm
46 is as low as it goes 170 on a climb, mind only 60
Posted : 18/12/2014 9:12 pm
 gazc
33 and 59bpm, mind thats after a lamb curry with 10000 cals, 6 coffees, 26 mile round trip commute & just got the bairn to sleep... maybe lower when i chill out! 🙂
Posted : 18/12/2014 9:23 pm
43 & it's high 40's.
Posted : 18/12/2014 9:25 pm
I'm 34 (& 51/52), and have a rhr of 40 currently.
Posted : 19/12/2014 7:47 am
38 rhr 75-85
theres a lot of really low heart rates here. sub 40 unless a super athlete, id be concerned!!
Posted : 19/12/2014 8:08 am
TBH it's usually mid 40s but I had just woke up so checked it using an app.
Posted : 19/12/2014 8:13 am
Page 2 / 2
