What would you do? ...
[Closed] What would you do? Selling question
I’m shortly going to put my Yellow Evil Sovereign up for sale. It’s only had a couple of runs since I bought it new. Question is do I take the frame protection off before I sell it or should I leave it on?
Any thoughts guys??
Posted : 12/03/2021 9:02 pm
Leave it on. Absolutely leave it on. It's a plus point (unless trashed) and if you leave it there is zero chance to you damaging the frame removing it.
Posted : 12/03/2021 9:05 pm
It depends whether the protection has gone yellow or not.
Nice stealth ad btw!
Posted : 12/03/2021 9:25 pm
Hmm..
I removed my Invisiframe on a frame I sold recently because it has got a bit torn and chipped, however once removed (easily with hairdryer) you could see the paint on areas not covered by the wrap had been lightened by UV so it looked a bit strange.
I'd leave it on and explain that if it looks tatt it's actually a plus that there's an expensive kit installed.
Posted : 12/03/2021 9:27 pm
I’d leave it unless it’s absolutely wrecked
Posted : 12/03/2021 9:39 pm
Cheers guys made my mind up and an add will go up shortly.
Posted : 12/03/2021 9:44 pm
I think the one time it could be a good reason to remove it would be if you were trying to pretend the frame had seen less use than it actually had. This is a bit cheeky and also you can run into the pitfalls as above.
I'd leave it on, unless the tape itself looks scabby.
Posted : 12/03/2021 9:53 pm
