What would a cx bik...
[Closed] What would a cx bike rear hub width be?
 csb
I have an old Forme Hiver frame to build up and it needs a new rim brake rear wheel.
It had an Ambrosio i20 wheel on it but i can't work out whether it (or indeed the frame) had a 130mm or a 135mm hub spacing.
Any ideas?
Posted : 10/05/2020 2:57 pm
135 on all the ones I've owned. Don't know about old timey stuff, presumably started with road frames.
Posted : 10/05/2020 3:00 pm
Rim brake is likely to be 130
Posted : 10/05/2020 3:03 pm
Canti brake 130mm (unless really old)
Disc brake usually 135 (some were 130)
Posted : 10/05/2020 3:06 pm
 csb
Get the calipers out and measure the spacing.
Posted : 10/05/2020 3:07 pm
 csb
That is the frame by the way.
Posted : 10/05/2020 3:08 pm
Can you measure it?
Posted : 10/05/2020 3:09 pm
 csb
I will have to measure it. No calipers but do have an old school ruler. Can't believe neither the frame nor the hub have it listed anywhere online.
Posted : 10/05/2020 3:11 pm
I can't believe you're first Instinct was to Google it rather than find your tape measure...
Posted : 10/05/2020 3:21 pm
As it’s a canti frame, does it really matter? Either a 130 or a 135 will usually fit just fine.
Posted : 10/05/2020 3:25 pm
 csb
Thanks everyone. Apologies for sofa based laziness cookea. You have helped me decide on a 135mm mtb hub squeezed in regardless.
Posted : 10/05/2020 7:37 pm
Not sure stressing an alloy frame like that is wise!
Almost certainly 130mm to take a road wheel. Just measure it, you dont need callipers to measure to the nearest 5mm!
Posted : 10/05/2020 7:50 pm
Agree, I wouldn't stretch an alloy frame. My money would also be on 130.
Posted : 10/05/2020 8:14 pm
I'd of thought a canti frame would be 130mm and a disc to be 135mm. I'd also be very wary of splaying an aluminium frame 5mm.
Posted : 10/05/2020 8:31 pm
My VN Amazon is 132.5 🙂
Posted : 10/05/2020 8:34 pm
+1 to 130 and not stretching an alloy frame
Posted : 10/05/2020 8:54 pm
 csb
Thanks again all. No splaying alloy. Don't be lazy and measure.
Posted : 10/05/2020 9:38 pm
