What waterproof spr...
[Closed] What waterproof spray for coats???
Since my water proof coat proved it isn't waterproof any longer after today's downpour....
What brand of waterproofing stuff do you lot use?
Posted : 03/10/2010 4:57 pm
I use Nikwax spray on, don't rate it very highly though, may try something else when i've finished my very large bottle of it.
Posted : 03/10/2010 6:05 pm
I just picked up some Granger's 2-in-1 this afternoon. I'll report back after I next get rained on...
Posted : 03/10/2010 6:14 pm
Before shelling out on Nixwax, or Grainger's, you could try re-activating the proofing, by tumble drying on a low setting, or ironing at a low-ish temp, worked for me with a Endura Venturi II. (which uses a ptfe based membrane.)
Posted : 03/10/2010 6:19 pm
tbh I've tried nikwax and grangers and neither seem to work very well.. the wash in is better than the spray on stuff.
Posted : 03/10/2010 6:20 pm
If your waterproof jacket is a laminate (gore/event etc) and is genuinely leaking, then it's time to say goodbye to it as the membrane has degraded to some extent and no amount of spray or wash-in will fix the problem.
If on the other hand, you have been wearing your jacket in warmish, humid conditions, the chances are you got wet from a mixture of stuff coming in through the holes (neck/wrist) and your own juices from perspiration. Reproofing with a spray or wash-in (more accurately - replacing the water [b] repellent [/b]finish) will help water bead off the jacket and should help with the apparent breathability of the jacket (i.e. more of your sweat gets out)
I use grangers wash-in on my goretex jacket and trouser and found it lasted longer than Nikwax. The new stuff doesn't need heat treating either, which is handy. I use the spray on stuff on my paramo too and haven't found any problems.
Posted : 03/10/2010 6:21 pm
