What valves can i u...
[Closed] What valves can i use for Tubeless on Nukeproof Rims (MTX 29)
as the title says,
i have mavic valves but there is not chance of them sealing, there is clear daylight,
show me something and tell me i dont have to use rim strips
Posted : 05/05/2010 8:08 pm
are they drilled for schraeder valves ?
try [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=46838 ]these[/url] - work best with an extra (smaller) o-ring added I found
Posted : 05/05/2010 8:14 pm
yer schraeder
where did you add the extra o?
Posted : 05/05/2010 8:19 pm
just rolled it on to the valve stem
This was on a flow rim - the indent in the rim looked a bit too curved for it to fit right without and the metal base of the valve has a sharpish edge that I didn't want digging into the rim. As the valve base is metal you can tighten down very positvely and get a nice rigid valve stem - some of the rubbery ones flop a bit I think
I've also used mastic bath sealant beofre now with good effect
Posted : 05/05/2010 8:23 pm
20 quid for 2 valves!
Posted : 05/05/2010 8:34 pm
M6TTF - Member
Yeh ! I'm sure they used to be cheaper - might have got 'em in the flood sale (But have ordered some more anyway)
Posted : 05/05/2010 8:52 pm
search ..bolt in wheel valve
Posted : 05/05/2010 8:59 pm
Posted : 05/05/2010 9:09 pm
