What tubeless setup...
[Closed] What tubeless setup stuff comes with Hope Hoops Flow these days?
Do you get tubeless valves? What tape is supplied as standard? What's the bare minimum 'ghetto gear' (hardware store) I need to get them tubeless with Hans Dampfs? (Hans Dampfs were previously tubeless with split tubes so should go up ok without kerfuffle)
Posted : 09/05/2014 10:19 am
Unless anything's changed recently, there's never been any tubeless stuff supplied with Hope Hoops Flow.
You'd need to take off the existing strip, fit some stans 25mm tape and a stans valve, plus the fluid.
Posted : 09/05/2014 10:22 am
Didn't get anything with my CRC order, just came with the standard green tape.
 nbt
Buy it from 18 Bikes and they will give you the tape and fluid 😉
Posted : 09/05/2014 10:23 am
Supplied with green tape as standard that needs removing. Cheapest option (assuming you have some spaff) is tape and valves from Superstar, £15 for both. For Flow EX get the 29mm tape rather than the 25mm as the 25mm isn't wide enough to cover the holes in the bead bench.
Posted : 09/05/2014 5:46 pm
nbt - Member
Just a got a set of hope tech wheels from 18 bikes: they'd fitted the tubeless tape, supplied two bottles of wheel milk & 2 tubeless valves. Hopefully the wheels will match 18's level if service.
Posted : 09/05/2014 8:21 pm
I use Superstar Valves with NoTubes sealant...and electrical tape instead of rim tape. Same setup as OP - Flow rims with Hans Dampfs Tubeless Ready. It works fine!
Posted : 10/05/2014 1:41 am
Buy from 18 Bikes as above
Posted : 10/05/2014 8:08 am
All fitted and working. Front went up with only a track pump, rear needed a blast from a compressor. This is the first tubeless setup I've done without a Schrader-valved bmx inner tube split down the middle. The shop flogged me a length of yellow rim tape similar to Notubes. I may replace the Notubes valves with Superstar alloy ones. I don't use the removable core to refill, I have an adapted tyre lever with a filling port.
Posted : 10/05/2014 11:12 am
