What travel fork fo...
[Closed] What travel fork for a Chameleon frame?
 rhid
I have recently built up a chameleon frame but need a bit of input regrding the fork!
What travel fork are you chameleon owners using?
The frame I have is the 05-06 version so will take up to 150mm. I was thinking of a 140mm fork (without travel adjust).
Any comments from anyone with experience will be very much appreciated!
Ta
rhid
Posted : 27/10/2009 9:48 am
I use a Thor at 140mm, it's pretty much spot for most stuff, Used a Reba at 115 for more XC stuff.
Posted : 27/10/2009 9:51 am
140 dual air pikes here. Perfect and still climbs well.
Posted : 27/10/2009 10:09 am
I use Pace RC41 Fighters, 150mm travel, they lock down in travel to lower the front end if needed/wanted when climbing. They seem to work really well with the frame geometry.
Posted : 27/10/2009 10:14 am
Manitou Minute 130mm. Also used 140mm pikes and that gave good geometry too.
Posted : 27/10/2009 10:38 am
i run some pikes on mine, up to 140mm travel and its quite sweet.
i did run my 160mm zocchi 55's on there for a bit, that made it quite slack at full travel, was good fun though.
Posted : 27/10/2009 10:56 am
 goog
160 bombers on mine ..... the bigger the better IMO
Posted : 27/10/2009 10:58 am
Running 130mm rev's, no travel adjust. Seems fine for pretty much everything.
Tried some 160mm Marzocchis (tall for their travel) and it was a bit too slack for me, even going downhill. they had travel adjust and i found them ok at around 120-130 though.
If i bought some new forks, it'd be Rev's again with blackbox damping, maxle and 140mm travel (no u-turn).
Posted : 27/10/2009 11:42 am
 gazc
i've got recons set at 100mm in singlespeed mode! ๐Ÿ˜ณ
Posted : 27/10/2009 1:26 pm
