What tool to remove...
[Closed] What tool to remove this?
Posted : 17/03/2018 10:29 am
Axle?
Posted : 17/03/2018 10:57 am
What do you want to remove?
Posted : 17/03/2018 10:59 am
Posted : 17/03/2018 11:00 am
Can't you lot read minds?
Sorry that wasn't clear at all!
The disc rotor lock ring thing
Posted : 17/03/2018 11:20 am
Hollowtech Bottom Bracket spanner (old wide type)
Posted : 17/03/2018 11:21 am
Its waaay to big. Tried that
Posted : 17/03/2018 11:27 am
Cassette lock ring doodah.
Edit, ignore me , I take it it's the carrier you want to remove.
Posted : 17/03/2018 11:31 am
If that is what its called , yes. The thing that holds the centerlock disc.
Posted : 17/03/2018 11:43 am
Can you even remove the carrier?
Posted : 17/03/2018 11:48 am
Confused. The lock ring is already removed in that picture. If you’re talking about the splined interface that matches the splined interface on the rotor, then you can’t remove it - it’s part of the hub shell.
What are you trying to remove and why?
Birmingham ScrewdriverBirmingham Screwdriver
Posted : 17/03/2018 12:28 pm
aha ok apologies. First time CL boost hub owner here!  I have an adaptor for a 6 bolt rotor that I want to fit see..
EDIT: file this under my most embarrassing posts. all fitted and sorted now. interesting my default thought was to remove/destroy.  🙂
Posted : 17/03/2018 12:33 pm
if this was stackexchange you'd have been burnt at the stake for this post
Posted : 17/03/2018 12:57 pm
Ha was totally lost trying to workout what you wanted to remove as I couldn't see anything except the subaxle inthe photo which could be removed but glad your sorted now.
Posted : 17/03/2018 12:59 pm
