What solution to re...
[Closed] What solution to remove adhesive?
Have a rubber downtube protector just received from charlie the bikemonger ( top bloke btw). Now it was originally on a Horsethief carbon but need to remove the adhesive backing before refitting it so I need:
1. To remove the old adhesive, and
2. Best method of sticking it to an alloy frame
Posted : 29/02/2016 12:43 pm
Is the glue on bare metal or a painted/lacquered surface?
If it's bare metal, nail varnish remover (acetone) will probably shift it the quickest.
If it's on a painted surface, try heat and/or WD40 and scrape it off with your nail.
Posted : 29/02/2016 12:47 pm
Sorry perhaps poor explanation on my part, just need to remove old adhesive from the rubber downtube protector and then reapply the downtube to a clean alloy frame.
Posted : 29/02/2016 12:49 pm
WD40/white spirit/pertrol/meths - try a few; one of them will work well for removing the sticky stuff.
something like this to restick it http://www.ebay.co.uk/itm/3M-x-20MM-AUTO-ACRYLIC-FOAM-DOUBLE-SIDED-ATTACHMENT-ADHESIVE-TAPE-UK-SELLER-/181700778986
Cheers anyone know of a liquid adhesive as opposed to a tape?
Posted : 29/02/2016 1:17 pm
I'd probably go with the tape; won't damage the rubber or your paint work.
Posted : 29/02/2016 1:18 pm
