What size Torx bolt...
[Closed] What size Torx bolt on new XT Crankset - T25 or T30?
I think I read somewhere that the chainring bolts take a T30 torx wrench rather than the standard T25 normally used for other bike fittings. Can anyone confirm this? I want to avoid rounding out the bolt!
Rich
Posted : 10/04/2014 11:19 am
its a T30 torx plus.
a standard torx will remove it - they are backwards compatible , but a torx plus will be a tighter fit.
Posted : 10/04/2014 11:56 am
Thanks trailrat, you saved my crank.
Posted : 10/04/2014 10:00 pm
They aren't using those on Cranks now are they? Torx bolts should be banned: They are the devil's work.
Posted : 10/04/2014 10:03 pm
Nowt wrong with torx- far superior to hex in many applications.
Monkey paws will destroy anything
Posted : 10/04/2014 10:08 pm
Torx is the way forward for me , much nicer to use than a nasty cap head Allen key bolt
Or maybe I should say hex to save upsetting people
Posted : 11/04/2014 12:09 am
