What size rear tyre...
[Closed] What size rear tyre for bike park
I usually run a super tacky hr 2.35 on the rear and a 2.5 front dual ply for uplift days.
Considering running 2.5 on the back too. Any reason why I should stick with a smaller rear apart from drag?
Posted : 08/03/2018 7:57 am
Clearance. Squirming if the rim isn’t wide enough. Easier drifting to tighten your line if the back has less grip than the front.
Posted : 08/03/2018 9:07 am
Clearance isn't an issue, nor rim width - flow mk3
Noted re grip though through corners!
Posted : 08/03/2018 11:02 am
