it's on a Kona Kula Lisa and I want to buy pretty pink seatpost clamp for the wife ๐
Posted : 03/12/2009 11:09 am
It's really "what size seatclamp for a Kona Kula Lisa"... I've no idea though.
Posted : 03/12/2009 11:10 am
It depends on the bike, not the seatpost size. ๐
A steel bike will have thinner tube walls than a alloy one, for instance.
The one that's on there might be marked up, but my guess is 31.8mm ๐
Posted : 03/12/2009 11:17 am
ok thanks. I'll try to find something to measure it with tonight
Posted : 03/12/2009 11:25 am
If it's a steel frame with a 27.2mm seat post, the seat clamp size is likely to be 30mm.
But measuring it will give you the correct answer.
Posted : 03/12/2009 11:39 am
it's an aluminium frame, but an Easton lightweight one so might be thinner than normal alu frames (?)
Posted : 03/12/2009 11:50 am
