What size bearings ...
[Closed] What size bearings for the main pivot on a Stumpjumper FSR?
Does anyone know what size the main bearings are for a Stumpjumper FSR. I think its the 2008 120mm travel version.
Is it easy enough to change them or are any special tools needed?
Posted : 05/09/2010 9:30 am
Changing the main pivot isn't too bad, the bearings are in the chainstays which makes ensuring they are in straight a bit harder- getting all the spacers etc lined up when re-attaching the back end is the most faffy bit!
Posted : 05/09/2010 9:48 am
BB Pivot Bearing
6802 RS (1524F) Series Full Complement Bearing - 24mm O.D. x 15mm I.D. x 5mm Width
Dropout Pivot Bearing
6800-2RS Series Bearing - 19mm O.D. x 10mm I.D. x 5mm Width
S-Link @ Frame Pivot Bearing
S-Link @ Seatstay Pivot Bearing
I did the hundreds of little buggers on my epic, I made a bearing press using bolts sockets and various washers. Appears to work ok, only buy decent bearing.
Posted : 05/09/2010 10:32 am
