Hiya chaps,
Given a progressive suspension curve, would reducing positive air volume and running less PSI produce better results compared to running normal positive air volume with more PSI?
By ''better results', I'm thinking plushness.
Rkcks
Posted : 15/02/2018 9:58 pm
it would, also fitting skf low friction seals will help for a plusher feel
Posted : 15/02/2018 10:50 pm
Cheers... I'm looking at rear shock, rather than forks...
Posted : 15/02/2018 10:55 pm
It’ll ramp up more but it’ll be sitting deeper into the travel, so it could feel more plush on small stuff but less plush when it gets rough (as you end up spending more time where the wheel rate is firmer).
Posted : 15/02/2018 10:57 pm
fit a coil
Posted : 16/02/2018 9:48 am
