What rim tape for r...
[Closed] What rim tape for running tubes on Stans ZTR Flow EX rims?
 edd
As I've asked in the title. What rim tape should I use to run tubes on 26" Stans ZTR Flow EX rims? If it makes any difference I'll be running 2.5" dual ply Maxxis tyres.
Comments advising me to run tubeless are welcome, but will be ignored. ๐Ÿ˜‰
Posted : 10/06/2013 11:32 am
Superstar 25mm did the job for me.
And I am running tubeless ๐Ÿ™‚
Posted : 10/06/2013 12:04 pm
Stans tape works perfectly well with tubes. Covered in the future as well if ever you change your mind about tubeless.
Posted : 10/06/2013 12:09 pm
 edd
Thanks - will probably go with the Stans tape.
Posted : 10/06/2013 12:26 pm
I had massive problems getting tyres on with cloth rim tapes. Ended up improvising with a thin strip of gaffer tape just covering the bottom of the channel.
Posted : 10/06/2013 12:27 pm
Stans or similiar tape- good quality electric tape will do it with a few wraps too.
Posted : 10/06/2013 12:29 pm
Another vote for using the yellow tape.
25mm Gorilla Tape from Screwfix. I've tried everything and this is by far the best.
Posted : 10/06/2013 12:53 pm
Superstar do the yellow tape cheaper than Stan's-branded stuff. It's exactly the same
Posted : 10/06/2013 12:57 pm
Ooops! Ignore ๐Ÿ˜ณ
Posted : 10/06/2013 12:58 pm
Stans. After struggling to fit the tyres with tubes you can go tubeless
Posted : 10/06/2013 1:17 pm
Electrical insulation tape, 2 wraps
Also works tubeless
Posted : 10/06/2013 11:01 pm
