I need a light-ish multi tool with a usable 15mm spanner and the normal range of Allen keys. Any ideas???
Topeak Hexus 2 or Ratchet Rocket.
Plus
PDW Wrencho
[url= http://www.charliethebikemonger.com/pdw-portland-design-works---3wrencho---tyre-lever-track-nut-spanner-807-p.asp ]PDW Spanner tyre lever thingy from Charlie The Bikemonger[/url]
Park Tool have some new one one their website that might be what you're after.
hexus
What's the 15mm for? Anything using a nut that big will usually want a bit of torque too so multitools are pretty unlikely to cut it. So if that's right in this case, then Hexus + 15mm spanner.
I think you could use a screwdriver-to-socket adaptor with a Ratchet Rocket though and get a little ratchet wrench.
Singlespeed axle nuts I am guessing.
A proper 15mm spanner is the minimum acceptable 15mm spanner.
I've answered my own question. I found 3 X Gerber Cooltools in one of the boxes of possible useful things I have in the garage. Sorted...
