What is wrong with ...
[Closed] What is wrong with my mech?
when i remove my rear wheel, my rear mech cage rotates clockwise to about the 1 o'clock position,
im guessing some sort of spring tension is borked
can i fix it?
Posted : 12/08/2011 6:22 pm
Sounds like the spring has moved. It can happen with a dodgy gear change. It's quite easy to take apart and relocate. Probabaly.
Posted : 12/08/2011 7:36 pm
di2 mech?
Posted : 12/08/2011 9:19 pm
Stop is broken?
Posted : 12/08/2011 9:20 pm
Cynic-al - I was going to say the stop, or perhaps the mech has slipped past the stop on the hanger? Although if that had happened I would think the shifting would be atrocious and unusable to begin with.
Posted : 13/08/2011 1:10 am
Mechs work fine when the stops are broken
Posted : 13/08/2011 2:41 am
+1, I can confirm this as my mech has a broken stop so I need to be careful removing the rear wheel otherwise it looks like and impossible puzzle with a mad chain twist....
otherwise its fine.
If it is the spring, pointy nosed pliers should allow you to grab the spring and relocate it where it ought to be.
Posted : 13/08/2011 5:35 am
