What is the best v ...
[Closed] What is the best v brake available/ produced??
One of my bikes is an old cannondale m2000 which wont take discs, so i'm limited to sticking with v's. I'm really looking to get this bike up to spec, so i'm after some v brakes, but i want the best there is in terms of stopping power ( which i know wont be alot compered to discs). Ive had a magura hydraulic rim brake before so not looking to go down that route.
Posted : 06/01/2014 9:55 am
Wanted ad for some XTR. XT are good too
Posted : 06/01/2014 9:58 am
XTR.
Posted : 06/01/2014 9:59 am
Any of the parallel linkage Shimano ones or Avid Arch Rivals. Adding a brake booster can make quite a big difference on older frames, too.
Posted : 06/01/2014 10:01 am
Avid SD7s are excellent
Posted : 06/01/2014 10:05 am
Thanks for the replies. At the moment, the brakes are avid single digit. Would the difference be very noticable between XTR's and single digits or are all v brakes within a narrow performance range?
Posted : 06/01/2014 10:08 am
Out of interest, why? By far the most powerfull rim brakes as long as you don't try an use lightweight XC rims with them..
+1, although older Cannondale frames are brilliantly/brutaly stiff depending on your preferance.
XTR with the parralelogram were more consistent than the normal XT ones (and single digits etc), but both were equaly powerfull when first set up, and seeing as pads rarely lasted into double figures of rides, especialy in winter when 2+ sets in a ride wasnt uncommon, the drop off in power at least gave you some warning before the metal bits hit the rim!
Cartrige pads are a must though, and ceramic rims if you can still find some.
Posted : 06/01/2014 10:09 am
Deore!
All the parallelogram cobblers on XT/XTR just over complicated what was basically a very simple pair of lever arms.
Actually I take it back, the old DX brakes, because Red is always the bestest...
Posted : 06/01/2014 10:11 am
IME because they're too good as a mud catcher. Couple of rides with them stopped the back wheel turning...
Anyway, to the OP, Old Shimano XT or XTR so long as the pivots aren't rattly.
Posted : 06/01/2014 10:13 am
Avid Single Digit Ultimates were amazing, and more expensive than most discs!
XTR on a practical level.
I'd say they probably are all pretty similar when working well. The difference is that the Parallel ones and the Arch Rivals tend to stay working well without adjustment for longer. I've got basic Shimano on my commuter and after a month or so the brakes pretty much stop working, a quick fettle with the allen key and they are sharp again.
Posted : 06/01/2014 10:14 am
Agree that parellel push were the best ones. It's not true that it over complicated things. They were more powerful and wore evenly with far less adjustment. Best i used were old LX parellel push in blue, brilliant. Found XT of the same era were not as good.
Posted : 06/01/2014 10:17 am
Original parallel push XT were good, the later ones squealed horrendously.
XTRs were very good. You used to be able to see the seat stays flexing outward on my OCLV hardtail when you squeezed the brakes, suggested the frame stiffness may have contributed to power (or lack of on both counts).
Posted : 06/01/2014 10:24 am
I totally agree with Njee's last post. Totally true of my itespeed obed frame when used with XTRs.
I also used KCNC VB1's on that frame which actually worked very well too.
Posted : 06/01/2014 10:33 am
Have got XTR Vs with severe condition pads on the Proflex and I think they're phenomenal. As above the seat stays flex before the brake arms but on the front it's just 30cm of brake cable attached to a set of Girvin Vectors they redefine one-finger braking
Good luck finding a set
Posted : 06/01/2014 11:00 am
 mrmo
pads matter more than the brakes themselves.
Posted : 06/01/2014 11:28 am
Ceramic rims and pads made a massive difference too.
Good luck finding some!
Posted : 06/01/2014 11:36 am
Best I ever used were the Cane Creek curved ones. Can't remember the name.
However, my ex's bike still has Deore's and they are very powerful. Great for skids. ๐Ÿ™‚
[edit]Direct Curve
Posted : 06/01/2014 11:38 am
The best ones I ever used out of XT M735, M760 and XTR M950 were the XT M760s. Revised pivot & parallel push design worked really well and didnt go rattly.
They never rolled out the revised design to any other brake oddly, as it deffo was better.
Posted : 06/01/2014 11:51 am
I found ceramic rims lasted far longer (obviously) but actually offered less power. Mavic ceramic rims weren't harsh enough to justify the ceramic pads either. The Bontrager ceramic rims (among others) were a far more abrasive coating.
Kool Stop Salmon pads were excellent.
Posted : 06/01/2014 11:59 am
*wipes away a nostalgic tear*
+1 for the parallel push XT / XTR. Having said that, my Magura rim brakes (were they called frogs?) were amazing. Laced to a snowflaked lemon XC713 / XT hub, on my first proper bike.
Posted : 06/01/2014 12:05 pm
My parallel XT squealed in use, replaced them with Avid TI Vs which I was happy with and light if that matters.
Posted : 06/01/2014 12:16 pm
 IA
Tell me you had some purple x-lite bar ends on there too? ๐Ÿ˜€
Posted : 06/01/2014 12:17 pm
Ceramic rims work best when you can get some heat into them.
This is fine when you live in Australia...
Posted : 06/01/2014 12:20 pm
Koolstop pads an some bitchumen
Posted : 06/01/2014 12:26 pm
