Help or suggestions please.
Need to locate a decent headset
Needs to be an integrated type suitable for a tapered head tube
IS42:52
Tried hope and cane creek, Chris king. Not found anything yet?
Thanks
Richard
Try FSA, they have loads of options. Good Luck!
Good call, will do thanks
Superstar have something, anyone know if they sell a crown race for the fork with the headset?
Thanks
Richard
I found this the most informative guide when I bought a new frame a couple of months ago - and, yes, I did end up buying Hope 'Mix and Match' headsets. Just don't order from CRC unless you are sure you know what you want as they don't sell one specific part as it competes with their own Nukeproof range.
HH I agree great guide but hope don't make what I need. Checked with them on Friday.
Richard
I just did 44 / 52 with a Hope Pick and Mix headset
The 44 is standard but the 52 is the bearing only which fits straight into the frame
What frame is it for?
Frankers thanks that's good to know.
Production Privee Shan.
I'll call them again on Monday.
R
From the size you've given, it sounds like you need an Integrated 'Campy style' tapered headset. CRC do one but it's bloody expensive:
http://www.chainreactioncycles.com/Models.aspx?ModelID=62142
Edit: or this from Privee:
http://www.production-privee.com/PBSCProduct.asp?ItmID=9773676
Edit 2: Superstar:
http://superstar.tibolts.co.uk/product_info.php?cPath=25&products_id=481
Dave, yeah I was looking at ss and pp ones, Not too sure about either as the pp shan has this open head tube badge and I was concerned about corrosion into btm bearing from water ingress.
R
From what I've heard, water will get into the Shan's headset anyway through the badge. ๐
That's what I mean sorry.
