[url= http://www.wiggle.co.uk/hope-pro-2-evo-mtb-rear-wheel-axle-conversion-kit/?lang=en&curr=GBP&dest=1&kpid=5360465759&sku=5360465759&ci_src=18615224&ci_sku=5360465759uk&ds_e_ad_type=pla&ds_e_ad_type=pla&utm_source=google&utm_term&utm_campaign=All+Products&utm_medium=base&utm_content=sLmKJRNfV_dc%7cpcrid%7c%7cpkw%7c%7cpmt%7c%7cprd%7c5360465759uk&dest=1&curr=GBP#tabAA ]Wiggle is listing X12 and 12mm thru kits.[/url]. Also, don't you need an axle too, or was that just with the old Pro 2 kits?
I'm pretty sure X12 is the 12x142 - the 12mm conversion is the 12x135 kit. That's what I got and it works :).
Evo hub only needs end caps - the pre-Evo one needed new axle etc. but the Evo comes with an axle that works with 12mm.
I've just called Hope to double check, it is the X12 kit I need. Cheers.
X12.
and the answer to your next question is chrome DS, black NDS.
Found this topic through google search.
Just to clarify-the OP's situation is the same as mine? I Have a EVO 135mm QR hub and need to make it 12x142 so I need the X12 kit? (to slide the Rockshox maxle through.
You are right. The complications arise if you have a pre-EVO version of the Pro2 - you need a new axle etc. For your evo, you just need the right end caps.
As above X12 is the 142x12 conversion - the 12mm one is the 135x12mm kit (older standard where the wheel doesn't locate in the dropouts before the axle is put in).
That is correct Hora
Cheers ๐
