What helmet mounts ...
[Closed] What helmet mounts do you use for torches?
Just had a DX P7 torch delivered and want to source a a helmet mount.
What are you using?
Posted : 30/09/2009 9:54 pm
 Elmo
Cable ties through the vents.............shimples 😉
Posted : 30/09/2009 10:01 pm
Fenix lockbloc
http://www.fenixtorch.co.uk/led_torches/lockblock.html
[url] http://www.dealextreme.com/details.dx/sku.12000 [/url]
For helmet use only, it won't let you mount on the bars.
Posted : 30/09/2009 10:07 pm
theboatman, how secure is it?
I remember a post from someone who got one for £3 in the UK delivered that looked good but cant find the thread.
Posted : 30/09/2009 10:10 pm
I have some lockblocks and when used on my handlebars they were wobbly as anything. The DX MTB mounts were much better. I figure it's just the same on a helmet unless I use zipties to semi-permanently tie it down.
Is there anything much better than a lockblock + zipties for a helmet?
/edit - seen the link from boatman - looks like it's wobble just as much unless it's much stiffer plastic than a lockblock
Posted : 30/09/2009 10:13 pm
Seems very secure to me, never had any concerns. It is identical to the fenix clamp, apart from the the fenix one can be used on the bars as well as your lid due to orientation of the bottom bit. You can get the velcro nice and tight, and the rubber doesn't slip around even if the wet.
Posted : 30/09/2009 10:33 pm
I fabricated my own from a bit of spare strapping, velcro, wide elastic and getting busy with a needle and thread.
Posted : 30/09/2009 10:38 pm
I've bodged one of the things that holds a pump on your frame. Works really well and doesn't damage my helmet.
Posted : 30/09/2009 11:04 pm
I use a TwoFish on the bars & the DX SKU12000 on my helmet. They do move a bit so I sourced half a dozen large 'O' rings in a couple of different Shore hardnesses to find the right fit. Half a dozen large rubber bands would probably have the same effect.
Posted : 30/09/2009 11:23 pm
Same here.
Posted : 01/10/2009 7:59 am
