What headset for fr...
[Closed] What headset for frequent fork swaps
 TimP
Headset are not particularly interesting bits of kit, mostly fit and forget so it is not something I can normally get too excited about but I feel I am shortening the lifespan of my current one by swapping in and out forks
What headset should I get to replace the very cheap no name one I have bearing in mind I will be swapping in and out forks fairly regularly (one frame for everything so rigid to sus). Ideally it wont require to much fiddling to get the right adjustment (would cartridge bearings be better?), and spare crown races will be readily available. Oh and not cost much. Doesn't have to be light though.
oh and 1 1/8"
cheers
Posted : 03/02/2010 10:34 pm
Get something with a split crown race..
Posted : 03/02/2010 10:36 pm
FSA XL2.
Split crown race, and dead simple to look after
 nuke
What they said
FSA XLII is what I use although not all come with the split crown race anymore so you may want to check before buying
Posted : 03/02/2010 10:37 pm
Hope, split crown as well
Posted : 03/02/2010 10:39 pm
sure somebody suggested that on here if a headset has cartridge bearings, it's okay to cut the crown race with a saw...is that true?
Posted : 03/02/2010 10:52 pm
OP wants something which has spare crown races available, no doubt in order to install one on each fork, so split races don't matter.
TimP I know you said cheap, but I'd honestly still get a Hope. They're brilliant, bulletproof things that you'll never have to worry about.
Posted : 03/02/2010 11:01 pm
 DT78
Um a had a pita fitting an FSA XLII last night. It didn't come with a split crown, in the end after an hour of faffing with a hammer and some wood I used a hack saw to make it a split crown so it fitted in seconds. As above my assumption is that as a cartridge bearing it'll be ok
Posted : 03/02/2010 11:08 pm
Cut mine and have no problems over the last year. I always put the split at the front so crap has less chance getting in.
Posted : 03/02/2010 11:09 pm
I've cut FSA "races"- it's not really a race at all of course but nevermind- and they work just fine like that. Some people say you shouldn't and that it "could cause issues" but they always seem to be a bit nonspecific on exactly what sort of issues it's going to cause.
Posted : 03/02/2010 11:10 pm
Hopes have a split crown. makes fork swaps easy and minimises risk of ruining the finish on your crown with a chisel.
Posted : 03/02/2010 11:11 pm
In theory you can cut any cartridge bearing "race" and it will be fine.
Posted : 03/02/2010 11:15 pm
I just use a few cheap M-Part headsets, cost a tenner, so having several bikes with a shifting population of forks is easy. They last surprisingly well, so my theory of treating them as disposable has hit the snag of them not needing to be disposed of.
Posted : 03/02/2010 11:18 pm
 DT78
Btw - I got the FSA XLII from merlin for the princely sum of £20. I wouldn't shell out for a hope headset again. I ended up replacing the bearings (at the cost of £10 each) in under 12 months use.
Posted : 03/02/2010 11:20 pm
Chris King cups are both the same so Ive got one King headset split between two bikes (on the bottom of each)
Spare crowns are easily available so Ive got one on sus forks and one on rigids and I swap them about quite regularly. Makes it really easy.
Not the cheapest for King but worth the money IMO. Just keeps working with no maintenance.
Do you jetwash?
Posted : 03/02/2010 11:45 pm
XL2 is a really good headset for £20. Hope is not 3 times as good! The Raceface Deus ones On One are doing for £27 posted are better than Hope. The RF ones are a 50-60 headset at £27. Really good deal. Only thing is they have the hardest and strongest crown race you can ever remove! Never had much luck with Hope Headsets.
Posted : 04/02/2010 12:01 am
 DT78
No jetwashing. A week in morzine with a couple of epic rainy days rides killed the bearings. Headset was fitted by LBS too so it wasn't me bodging it. Took it back to said LBS and was told they weren't warrentied. Not best pleased.
Fatbirds do the RF deus headset cheap too, though I've heard dubious reports on various forums so went for the XLII this time.
Posted : 04/02/2010 12:07 am
thanks 🙂
true I suppose, what are they called then?
Posted : 04/02/2010 8:21 am
"Baseplate" 😉
Posted : 04/02/2010 8:52 am
Easiest thing to fit crown races with (Apart from the proper tool!) is a length of plastic waste pipe. There's a size that **just** fits over a steerer tube, then belt it with a hammer. Cheap and effective, I find.
You know, that's a bloody good idea IMO. It's always the bottom race that fails first on cheaper headsets too. Thanks for that! 🙂
Posted : 04/02/2010 9:09 am
Dia Compe CB-2. Only £32. Alloy and catridge. Loads of colurs and the all important split crown race so you can move between forks in seconds with no tools needed other than an Allen key.
It's the only headset we sell and what I use on all my bikes. Works real well. Never had a single problem.
Posted : 04/02/2010 9:29 am
