What grease on fram...
[Closed] What grease on frame pivot bearings?
As above, just rebuilding my frame - a NP Mega if that makes any odds? Got copper anti-seize and some Teflon TF2.
Cheers,
Kev
Posted : 10/01/2014 6:14 pm
 JoeG
Are you asking what grease to use when pressing the cartridge bearings into the frame?
Or are you asking what grease to put inside the cartridge bearings?
Posted : 10/01/2014 6:27 pm
There's sealed bearings which are new, so fine. Then there's the cylindrical bushings, which I'm thinking need lubricating? Sorry, probably a poorly worded question.
Posted : 10/01/2014 6:30 pm
i would use copperslip on threads and teflon on surfaces.
Posted : 10/01/2014 6:31 pm
If they are a bush they are often supposed to be put together dry. I'd check with nuke proof if I were you.
Posted : 10/01/2014 6:35 pm
It was going to be blue loctite for the threads......due to the design and sealed bearings it looks as though all/most movement happens within there, so I think I'm really just wanting to keep all the crud out!?
Posted : 10/01/2014 6:36 pm
