What fork for On-On...
[Closed] What fork for On-One 456?
 AWi
As per the title - what recommendations and experiences with different forks for the On-One 456? It will be used for trail riding. Looking at getting a 140mm fork. Looking at e.g. Fox Vanilla R and the new Revelation dual-air.
Terrain around here - singletrack, lots of roots and rocks, flat, very little climbing
Thanks
Posted : 31/01/2009 4:39 pm
I'm running pikes on mine, maybe a touch heavy but work really well with the bike, I use mine for riding a bit of everything
Posted : 31/01/2009 4:47 pm
your riding sounds like my local stuff in bristol. My 456 had a revelation on. 100mm was scary fast but fun, 115 a perfect for the singletrack and 130 good for the steeper stuff. For you, it really depends on what you ride most. For me, 140 would have been too much.
Posted : 31/01/2009 4:57 pm
I run Pikes on my 456 but for general up and down trail stuff I usually run them at around 125mm. Any more and the steering is a tad slow. Only in the Alps do they stay on full travel all day.
Posted : 31/01/2009 5:00 pm
 AWi
Thanks for the feedback.
reggiegasket - you mention the steering will be slow with a Pike at 140. What stem length do you run?
I was looking at getting a 60 or 70mm stem for the 456.
Any tips on great prices for 140mm forks currently on sale?
Posted : 31/01/2009 5:15 pm
Anyone used recon 351 uturns (85-130) Ive heard they are similar fork to the revelations.
Posted : 31/01/2009 5:17 pm
Mates just bought a set of Pikes for his.I have pikes on my Soul, can't recommend them enough
Posted : 31/01/2009 6:05 pm
He got his pikes from Merlin BTW
Posted : 31/01/2009 6:06 pm
Revs on mine at 130mm. Smashing.
Posted : 31/01/2009 6:21 pm
I've just bought Pikes for mine.
Winstanley's have 2005 Pike Race for £259[url= http://www.winstanleysbikes.co.uk/product/4981/RockShox_Pike_Race_UTurn_Forks_2005 ] here[/url]
and 2006 426 for £269 [url= http://www.winstanleysbikes.co.uk/product/7394/RockShox_Pike_426_UTurn_Forks_2006 ] here[/url]
Look like good prices but there are always 2nd hand Pikes for sale on here
Posted : 31/01/2009 6:55 pm
I run a 70mm stem on a 18" frame. I'm 5'11'.
For anything downhill, the setup is really good. Manoeverable, chuckable etc.
But for climbing a singletrack it's a tad slow steering unless you drop the fork to 120 or less. Then it's fine.
Posted : 31/01/2009 7:18 pm
recons are the same length as revelations at a given travel give or take but i didn't think that recons have a 130 mm model. Are you sure they're not toras?
Posted : 31/01/2009 7:20 pm
also i'd suggest that slow is relative. For steep stuff you want slower handling eg 130+ travel but it's not ideal for flat singletrack as it may feel a bit heavy and or slow even with a short stem. Of course it'll all depend how you like your bikes to handle.
Posted : 31/01/2009 7:24 pm
 hora
I have a set of 2005 Pike SL's on mine (also from Winstanleys recently!). Pikes can be wound up and down. Otherwise a set of WORKING Mazz 55's????
Will someone PLEASE buy those Pike Race's from Winstanleys- they are alot better quality than the 409/426's. Better decals and paint finish!
Manitou Nixon Air something damping on mine. 140mm allways on, 70mm stem, no complaints. If it can't climb it means I'm uselessly unfit.
Posted : 31/01/2009 7:33 pm
COIL PIKES (imo)
Posted : 31/01/2009 7:56 pm
 AWi
What a great Saturday night 🙂 In front of the bike forum after having spent a few hours out riding the FS in the snow and ice.
Thanks for all the great feedback! Pike seems to be the weapon of choice for a 456 frame. I currently run a old Revelation u-turn and a 36RC2 talas on other bikes but a Pike is still missing in the garage.
As Hairychested mentions he favors the coil Pike. There is a u-turn air version as well.
So ... what experiences on Pike coils vs Pike airs?
Thanks again!
Posted : 31/01/2009 8:11 pm
coil is slightly more plush but may mean forking(!) out for a new set of springs if you're not average weight.
Air is more adjustable and lighter.
I prefer air
Posted : 31/01/2009 8:19 pm
Buy them from your friendly neighbourhood LBS and they'll do a spring swap free if you need it. IME 99.9% find the standard coils OK anyway. Works better (again IME)and saves all that faffing and bothering about "have I got the right p.s.i, has some leaked out, etc, etc"
I prefer coil 😉
BTW I do have a hairy chest, but I'm definitely not "hairychested" (the STW member) - he wasn't very nice to me yesterday so I thought I'd clear that up!
Posted : 31/01/2009 8:26 pm
i don't find that i have to check my air revs very often and i can easily change the spring rate for different riding but like i kind of said, each have their advantages
Posted : 31/01/2009 8:33 pm
Spot on there clubber, a personal choice thing at the end of the day.
Mind you, I dont have to check my coils at all, let alone "not often", they always work OK! 😉
Posted : 31/01/2009 8:44 pm
 hora
Buy them from your friendly neighbourhood LBS as they will charge you a friendly £450.
Or buy for £259 online and follow the very easy instructions that Flooks will send you. It is so simply that I managed to swap the spring 8)
Posted : 31/01/2009 9:28 pm
Hora, your LBS isn't as friendly as mine then! (454's £275 fitted)
I do buy alot of stuff there though and have done some stuff at my work for the lads that work at the bike shop in return.
Posted : 31/01/2009 9:33 pm
