What else needs cha...
[Closed] What else needs changed if the steerer is longer?
[#12070911]
Got a Bird Aeris 120 LT in large...I'm 6'1" and it fits well - but does look small.
Having ridden in a standard 90s position since I started, I'm thinking I need to raise the handlebar a bit so I can see further ahead.
Handlebar is about 5" lower than my saddle but I'm lanky so need the saddle up.
So I'm thinking I'd maybe like new forks and with that means I could leave the steerer long and raise the bar a bit...maybe 20mm at most. However that will move the bar back a bit, so what else do I need to change?
I'm thinking a slightly longer stem to compensate for the closer position - if that is right, how much longer?
I'm just having a think just now as forks aren't in stock so plenty of time to consider but I'm also needing to consider what else needs changed if I do get the bar moved up by using a longer steerer.
Thanks.
Posted : 12/10/2021 6:35 pm
Why not just fit some riser bars? You'll have the added advantage that you can play with reach by twisting them forward or back. A lot cheaper than new forks, you can even try a few different ones and still have a lot of change
Posted : 12/10/2021 6:48 pm
Forgot to say, bars are 35mm rise and I'm not keen on going higher as it'll look like a BMX! 😉
Posted : 12/10/2021 6:51 pm
 5lab
get a stem with a bit of rise (or a bit more rise) than you currently have?
Posted : 12/10/2021 6:59 pm
Im 6-1 if I really stretch, and on the same bike. But we are clearly very different shapes:
Handlebar is about 5″ lower than my saddle but I’m lanky so need the saddle up.
My bars are level with the saddle when it is in the pedalling position
To answer the first question:
raise the bar a bit…maybe 20mm at most. However that will move the bar back a bit, so what else do I need to change? I’m thinking a slightly longer stem
~10mm. But dont. You're compromising (or at least affecting) the handling, to allegedly improve seated fit. Thats a big no-no on a modern trail bike.
If you are raising the bars you will be rotating your body back - pivoting at the hip. In which case, you don't want to be maintaining the same ETT number, as it wont be comparable.
Posted : 12/10/2021 7:04 pm
Can you buy a stem with some rise if you won’t buy riser bars?
Buying a new fork seems a bit OTT to me.
Posted : 12/10/2021 7:05 pm
Stem is a 40mm and suspect zero rise...will I need to increase length if height rises? If so, it won't surely be 1 for 1 so a 20mm rise of steerer won't be 20mm length added to stem, but I'm not sure what it would be...
I'll see if I can find any stems with some rise on them, I'm guessing very few 40mm stems that fit a 35mm bar...
Posted : 12/10/2021 7:06 pm
@ayjaydoubleyou - so I leave stem alone?
I'm proper lanky...34" inside leg and arms aren't much shorter...all seems proportional but I'm lanky...saddle is high - I've a 150mm dropper with about another 50mm of post sticking out...so it is high.
Ride position is comfy, but I'm thinking I need to try to raise bars a bit to allow me to look up and ahead more as I've grown lazy and I'd like to get faster so need to be looking ahead more - not so easy with backside way up as I'm clearly not as flexible as I used to be!
Posted : 12/10/2021 7:10 pm
bars 5" below seat is a really weird riding position for an MTB
Posted : 12/10/2021 8:13 pm
"bars 5″ below seat is a really weird riding position for an MTB"
even in the 80s...
Posted : 12/10/2021 8:24 pm
Burgtec do a 50mm rise bar, that and/or a new air spring g to increase fork travel might do it.
https://burgtec.co.uk/product/josh-bryceland-signature-alloy-handlebar-ride-high/
Posted : 12/10/2021 8:39 pm
Forgot to say, bars are 35mm rise and I’m not keen on going higher as it’ll look like a BMX!
Who GAS what it looks like.
Spot the short-arses.
35" inside leg here and until bikes started to be properly sized I always ended up with bars far lower than seat.
I've a 29er plus 50mm spacers and 38mm risers - and 70mm of a 170mm dropper sticking out of the seat tube... My HT is running a 200mm dropper, with post showing.
Amazing how much easier it is on the super steeps with bars nearer saddle height, rather than way below.
Posted : 12/10/2021 8:51 pm
It does sound like a big drop between saddle and bars, I'm 6'5" and don't have that much drop! I've got quite a lot of headset spacers, high rise bars and dmr defy stem to try and raise the front as much as I need.
Posted : 12/10/2021 8:52 pm
I think the OP recognises that the bars are very low, hence the questions regarding how to raise them!
Posted : 12/10/2021 9:35 pm
Right, more rise on the bars and see if I've room to lift the stem any more then...I'm saying 5" it is likely to be less than that, but it was more the fact the bars are much lower than the saddle...as someone has said, not always possible for taller riders to get bar at same height as saddle, but it has worked for me up until recently (which suggests I've been a really bad rider all these years if I'm just finding it out now that it isn't the best position for going faster!)
Thanks for the input, it has been useful so far.
Posted : 12/10/2021 9:39 pm
Depending on what the forks are worth it may be cost effective to just replace the steerer?
Obviously if you want new forks you want new forks!
Posted : 12/10/2021 10:54 pm
DMR defy stem is low stack with a 5mm rise.
Posted : 12/10/2021 11:10 pm
Thanks, useful to know.
Posted : 12/10/2021 11:11 pm
Errmmm - riser bars, angled stem etc.
Ok Im a dwarf but ..................
Posted : 12/10/2021 11:55 pm
Inches or centimeters? I used to run XC bikes with the bars about 2" below the saddle. Now I run pretty much all my bikes with the bars level with the saddle. 5" is pretty extreme.
Some riser bars and longer stem with more rise will be a lot cheaper than a new fork. If you're worried about what people think, just keep in mind that you look ridiculous with your bars 5" below your saddle and your arse poking up in the air.
https://www.chainreactioncycles.com/spank-spoon-800-skyscraper-riser-handlebar/rp-prod197255
Posted : 13/10/2021 10:14 am
Nukeproof Horizon 38mm rise bar is good, I used that with a DMR Defy stem (which has a slight rise as well) when I had a shorter steerer.
I could sell you the Defy stem if you wanted to buy a 31.8mm high rise bar.
It doesn't look weird, a lot of the cool kids are running high-rise bars now as they don't compromise the bike's reach so much as going higher up the steerer.
Posted : 13/10/2021 10:24 am
Also a longer crank will bring seat down a bit.
Posted : 13/10/2021 10:26 am
a lot of the cool kids are running high-rise bars now as they don’t compromise the bike’s reach so much as going higher up the steerer.
If your grips are in the same position relative to the cranks and saddle, it makes no difference to the reach whether you run riser bars or a longer steerer. If you have the bars higher, the effective reach will be shorter.
Posted : 13/10/2021 10:50 am
What forks are on there and how much travel are they running?
I’ve got an aether 7 which is quite similar and running 150mm forks on it. I think the headtubes on Bird can be quite short - I’ve got quite a stack of spacers under my stem / 25mm rise bar.
Posted : 13/10/2021 10:52 am
Pike Select at 140mm, steerer has a 5mm spacer above stem so I could lift bar slightly...off to go replace the bars with a higher rise as well...
Posted : 13/10/2021 10:57 am
They're not, that's the point innit?
Posted : 13/10/2021 11:01 am
They’re not, that’s the point innit?
It doesn’t look weird, a lot of the cool kids are running high-rise bars now as they don’t compromise the bike’s reach so much as going higher up the steerer.
There are different ways of raising the grips. One is to put spacers under the stem. Another is to fit a stem with more rise. Another is to fit bars with more rise. All of these will reduce the effective reach. If the grips end up in the same position, the effective reach will be the same. It doesn't matter how the grips got there, just where they ended up relative to the BB.
Posted : 13/10/2021 11:09 am
The DMR defy stem is only 5mm rise but because the stack is very low you can have it further up your steerer (more spacers below) and get a bit more height than with another 5mm rise stem.
I think the saddle to bar drop is a bit of an old school thing, shorter bikes needed more weight over the front as the reach/chainstay was much less. I had a big drop on my old 26" bike but now it's probably only 1" on my 29er but the reach has grown by 70mm. There isn't a right or wrong answer but modern geometry will generally let you have a higher bar for a more comfortable position.
Posted : 13/10/2021 11:22 am
Replace the steerer for a longer one. These guys do loads, check their Insta.
https://www.rsfsus.co.uk/
Posted : 13/10/2021 11:37 am
A high-rise bar keeps the grips further forward than a low rise one higher up the steerer.
Does that make sense to you now?
Posted : 13/10/2021 11:42 am
Reach isn't measured to the bars, it's measured to the steering axis. It's normally measured at the top headset bearing, but that's not useful if you raise the bars a lot. The effective reach is measured to the height of the grips. It's still measured to the steering axis. The higher the grips, the shorter the reach. It makes no difference whether you use riser bars, a riser stem, or put spacers under the stem because the steering axis does not move.
Does that make sense to you now? (Hint: You have to think about what reach actually is before you will understand it.)
Posted : 13/10/2021 11:55 am
You were talking about grip position.
High rise bars also enable the stem to be clamped lower down the steering axis.
Posted : 13/10/2021 12:00 pm
It doesn't affect the reach. If you have the grips at the same height, the reach is the same. If you lower the grips, the reach is longer. If you raise them, the reach is shorter.
Try thinking about it and it might start to make sense. You could even draw a picture if that helps.
Posted : 13/10/2021 12:05 pm
Stated frame reach is the measurement out from the BB to a point parallel with the centre of the top of the head tube.
It's a bit of a vague measurement because head tubes vary in length, but if you consider the variables, it's still a great indicator of how well a frame will fit.
Clamping the stem higher on the steerer can artificially reduce the reach a bit, by bringing back the effective centre of the top of the head tube. Thus keeping the clamp point lower and using high rise bars preserves the reach.
Stop being sanctimonious and think for a minute about what I'd written. I'm going to leave it here because if the penny doesn't drop now, it never will.
Posted : 13/10/2021 12:19 pm
It does no such thing. The stated reach is to the top headset bearing. This is not much use if you raise the bars a lot. The effective reach is to the point on the steering axis at the level of the grips. This is the most useful indication of how well the bike will fit a given rider. It makes no difference whether you put spacers under the stem, use a riser stem, or a riser bar; if the grips are at the same height relative to the BB, the reach is the same. The only thing that matters to effective reach is how high the grips are.
Stop being sanctimonious and think for a minute about what I’d written. You really do not understand this very simple geometry question.
Posted : 13/10/2021 12:24 pm
I have a 35*31.8 defy in my parts box, PM me if you are interested
Posted : 13/10/2021 12:37 pm
@ayjaydoubleyou – so I leave stem alone?
If you like how it corners now, yes or you'll just be swapping one issues with another.
I’ve a 150mm dropper with about another 50mm of post sticking out…so it is high.
I've got a 170 dropper with about 40mm sticking out the frame on the same large 120LT. So I think that your 5 inch is quite a way off. I have a photo (that I cant figure out how to post) of my bike, proped against a fence with the bars turned, taken from a bit of an angle, and I can see how it appears that my bars look 4-5 inches below saddle. The heavily sloping top tube is also helping with this optical illusion.
But if I put the bars straight and photograph it in line, with a nice background like a brick wall with a horizontal line for reference the saddle and bars are about level.
I have (I think) 15mm spacers, 40mm rise bars, 35mm long stem with no rise.
Posted : 13/10/2021 2:11 pm
How long are your legs?
Posted : 13/10/2021 2:13 pm
 LAT
if you raise the height of your grips by putting spacers under the stem, the position of the grips will move towards the saddle as well as upwards
if you raise the height of your grips by fitting a higher rise handlebar the grips will only move upwards.
to picture this, imagine a 0mm length stem. to raise the grips with spacers the stem moves up and back, moving the grips up and back dictated by the angle of the head tube. if you put a higher rise bar on the same imaginary stem, the grips will only go up as the rise of the bar is completely unrelated to the angle of the head tube, but it will put the grips in a different location relative to the steering angle, but so would changing to bars with a different back sweep.
to reply to the op’s question, if you want the bars higher, but without moving your hand position backwards, i’d say a higher rise bar is best. there is a german brand, ergotech or similar name who make bars in many shapes. they aren’t the lightest, but they are well priced and that makes them ideal for experimenting.
Posted : 14/10/2021 1:44 am
Reach is the horizontal distance from the BB axle to the steering axis. It's not to the grips, it's to the center of the steerer. Fitting a longer stem does not increase the reach, it moves the bars forward. Raising the grips by fitting riser bars will reduce the effective reach, even if the grips haven't moved horizontally. This is because reach is not measured to the bars, but to the steering axis.
Manufacturers publish reach figures measured at the top of the head tube. This is not particularly useful if you are tall and run your bars a lot higher than stock. A much more useful measurement to determine whether a bike will fit a specific rider is to calculate effective reach at the level of the handlebars. This is basically the reach measurement you would get if you extended the headtube enough to run a zero rise stem with flat bars. By raising the bars, you will always reduce the effective reach.
It does not matter how you get the grips to your preferred height. You can fit spacers, you can fit a riser stem, you can fit a riser bar. The only thing that matters as far as effective reach is concerned is the height of the grips. If you raise your grips by 50 mm, the effective reach will be reduced by about 20 mm.
Having found a suitable height for your grips, you can then try different stem lengths and bar sweep to find a comfortable setup for you. Provided you are not changing the height of the grips above the BB, this does not change the reach because the reach is measured to the steering axis, not the bars.
Posted : 14/10/2021 4:07 am
I’m a 33inch trouser if I can find them, otherwise usually 32. Don’t know what my actual physical measurements are.
Our seats must be within an inch or each other, based on seatpost length and insertion.
Posted : 14/10/2021 10:29 am
I'm similar. 6'3" with 34" inseam, 36" to floor.
Long story short, longer stem.
Riding in attack position didn't work on my XL San Quentin. Short 35mm stem, basic 28mm low riser bars, 30mm of spacers under the stem. I was hunched over, no strength to control, too far forwards.
I considered extending the fork travel, but then the head angle would go out, and handling at all times. Seatube angle would be out too, limiting saddle position and angle. Getting the parts for that where I am was near impossible anyway.
I got some 90mm fmfxtr riser bars. Not too much upreach on them. Cheap and nasty Chinese ones. Still didn't work for me.
Dealer told me I'd be needing a longer stem off the bat. I'd tried 45/60 out of my parts bin. It was only by sticking on an 80mm 7deg stem in conjunction with the really high bars that I fit the bike. Dabomb Shark 80mm 7deg on there now. Handling isn't noticeably upset. I think extending the fork would have been to detriment. I may try lower, branded bars I trust, but I think this is my solution to being lanky.
Posted : 14/10/2021 11:48 am
What is "upreach"?
Posted : 14/10/2021 12:32 pm
thats a lot of rise! do you run them vertically, in line with the fork/headtube angle, or somewhere in between?
the "effective stem length" - or distance from grips to steering axis is going to vary hugely with that much bar rise
Posted : 14/10/2021 12:40 pm
the “effective stem length” – or distance from grips to steering axis is going to vary hugely with that much bar rise
It will also generate a lot more torque on the bars under braking on descents. The first time I fitted some riser bars it was to an XC bike with a two-bolt stem. They were probably about 2" rise bars and I obviously didn't tighten the stem cap enough because the bars rotate forwards on the first rough descent, which meant I couldn't reach the brake levers. Very exciting experience, I recommend everyone should try it once.
Posted : 14/10/2021 12:54 pm
