What DX Torch for a...
[Closed] What DX Torch for a helmet light (sorry) ?
Hi,
I know there has been a few DX light threads of late so sorry to start another, but I'm after a flashlight to use mounted to my helmet to be used alongside one of the original DX 900 lumen lights that I have mounted on my bars.
Obviously there are a lot of options on DX and I can fairly easily pick a 900 lumen flashlight with an 18650 battery. What I'm after is if anyone has a recommendation they can make based on experience for a unit that performs well, has been reliable and that is reasonably weatherproof.
My current thoughts are one of [url= http://www.dealextreme.com/p/fandyfire-501b-ssc-p7-3-mode-900-lumen-white-led-flashlight-with-strap-black-1-x-18650-57985 ]these[/url] mounted using one of [url= http://www.dealextreme.com/p/universal-nylon-mount-for-flashlights-and-lasers-12000 ]these.[/url]
I'd be grateful for any pointers...
Posted : 26/08/2011 4:54 pm
I've been using a couple of TR-801s as helmet lights for the last 18 months and they've been great even though they're only 230 Lumens.
I can't comment on the P7 light you've linked to although I've just ordered [url= http://www.dealextreme.com/p/fandyfire-a10b-cree-xm-lt6-3-mode-900-lumen-white-led-flashlight-w-strap-1-x-17670-1-x-18650-90607 ]This XM-LT6 Light[/url] which is smaller and lighter than the P7 one for similar money.
The mount works fine - get a couple coz they're always useful.
Posted : 29/08/2011 8:11 am
I got one of these and the little nylion mount last year.
http://www.dealextreme.com/p/ultrafire-c1-cree-r2-wc-5-mode-memory-led-flashlight-2-cr123a-1-18650-14443
It's been great. I get a decent runtime, even with it on high. It's only 250 lumens, but it's very focussed and throws the light far. It basically throws a wee spotlight on what you are looking at, which is what you want, really.
Cheap and light also.
I just bought one of the mega cheap assault crown XML lights. It's on the bar, and has replaced the old P7 torch I was using. It has quite a focussed hot spot too, and a fair old throw, so I'm thinking it might make a decent head light. I may relegate it to helmet use next winter.
Posted : 29/08/2011 8:39 am
ive been using a p7 for a couple of years on my helmet, works a treat, im punting it with a charger and three battery's if your interested
Posted : 29/08/2011 8:46 am
 benz
This dx torch, assuming you have 18650 batteries, etc already does not look bad for the cash....
http://www.dealextreme.com/p/ultrafire-wf504b-xm-lt6-5-mode-510-lumen-white-led-flashlight-with-strap-black-1-x-18650-57099
Posted : 29/08/2011 11:07 am
 benz
Should also work fine with USE Exposure helmet mount...well the MCE and P7 ones I have do just that no probs....just ensure that you get the smaller diameter exposure mount....
Posted : 29/08/2011 11:09 am
I'm running the XPG version of this:
http://www.cnqualitygoods.com/goods.php?id=1060
great little torch and fits perfectly in a Joystick helmet mount!
Posted : 29/08/2011 11:11 am
I was looking at those little Yezl lights - are they floody or focused?
Posted : 29/08/2011 12:54 pm
Thanks for all the replies. It's certainly given me some more ideas...
Craig YGM, if that does work out I think I'll go with Benz's suggestion...
Posted : 29/08/2011 2:54 pm
Which ever one you choose (I got a P7 MCE ages ago - XML would be my choice now), I recommend making sure it has more than three modes (high/low/flashing). You may end up with another annoying flashing modes, but the low on these units are far too low (high too much for road use), you need a low/medium/high settings to get the best out of them IMO.
Posted : 29/08/2011 3:13 pm
 rob
this one
http://www.dealextreme.com/p/ultrafire-th-t60-ha-ii-xm-lt60-5-mode-1200-lumen-white-led-flashlight-with-strap-1-x-18650-904457007
high/med/low plus 2 flashing settings
using one on the bars
1 battery lasts me a weeks commute on a mixture of low and med settings
seems fairly well put together, double o ring seals on tail cap have kept it dry inside
just bought another one off ebay to use on me head for £12
Posted : 29/08/2011 3:37 pm
Sigh......
Posted : 29/08/2011 5:51 pm
