Hello!
I'm finding the horizontal foetal position I have to adopt to reach the drops on my Peugeot Carbolite increasingly uncomfortable on my 9 mile commute.
I'm thinking about looking for something a bit lighter, and a lot more comfortable. It must be steel and have mudguard / rack mounts too.
What sort of thing should I be looking at?
Dawes Galaxy crossed my mind, but eager to hear any recommendations.
Thanks!
If you’ve got a local bike recycling place or CIC you can probably pick up a really cool looking 90s MTB, or maybe an old tourer, for under that price. Feeling like your bike is cool adds about 20% lateral and vertical comfort 🙂
Thanks, that's a good tip!
I thought that my Peugeot was cool, but the bonus 20% comfort still leaves me about 40% below threshold.
Couldn't you just change the bars and brake levers on the Peugeot?
Facebook marketplace has a good few hybrid or touring steel bikes all the time near us.
I would pick what is best from the selection offered, rather than seek a specific model.
e.g.
Hub gears
Specialized cx
Hybrid
https://www.facebook.com/marketplace/item/727729429097518/?ref=facebook_story_share
Lovely old tourer
https://www.facebook.com/marketplace/item/872649930489336/?ref=facebook_story_share
Newer tourer
https://www.facebook.com/marketplace/item/1534979453579934/?ref=facebook_story_share
Modern tourer
https://www.facebook.com/marketplace/item/486297653705652/?ref=facebook_story_share
Couldn’t you just change the bars and brake levers on the Peugeot?
The geometry is so aggressive I'd assumed it's beyond anything a taller stem could solve, but this is a good idea - I'll take a look.
I would pick what is best from the selection offered, rather than seek a specific model.e.g.
Hub gearsSpecialized cx
Hybrid
https://www.facebook.com/marketplace/item/727729429097518/?ref=facebook_story_shareLovely old tourer
https://www.facebook.com/marketplace/item/872649930489336/?ref=facebook_story_shareNewer tourer
https://www.facebook.com/marketplace/item/1534979453579934/?ref=facebook_story_shareModern tourer
Thank you!
The geometry is so aggressive I’d assumed it’s beyond anything a taller stem could solve, but this is a good idea – I’ll take a look.
Assuming we're talking about an old road bike, then yes you can just swap to either flat bars + cantilever levers (because V-brake levers, aka. linear pull, have the wrong pull ratio) is a comfortable option, albeit it makes the steering a bit quick.
Failing that, and suggesting what you own. Have a look for the aluminum version of the Charge Plug, it's not a harsh frame at all and takes 40mm+ tyres. I've got a singlespeed one set up as a fixie for long commutes upto 25 miles and it's the best tool I've had for that job.
Charge Plug are cheap and quality
Whatever's on ebay or whatever locally. I don't think a galaxy is going to be any better at all so perhaps the answer is a hybrid.
I have a Charge Plug that I'll be listing on classifieds/eBay next week. Size medium. Will be well within your budget.
I used it for many miles of comfortable commuting and have racks/guards that I'll happily sell with it, along with a spare set of wheels with gravel tyres.
I think it is a 2015 or 2016 model, whichever year they decided to do alloy with carbon fork rather than steel.
PM me if interested.
I'm pretty sure they ran in parallel for a long time, the Plug 0 was the steel fixie with normal road bike proportions and tyre clearance, the Plug 1 was the alloy one with massive clearances for gravel tyres / guards and very modern even now 'slack' head angle and shorter stem than a lot of gravel bikes, plug 2 was a 1 with gears. Later there were disk braked versions of the 1 and 2 as well.
There was a also the Grater which was I think a Plug 2 with a flat bar.
I meant a shorter stem and a flat bar, not unheard of, I might even have an old 1" quill to 1-1/8" ahead adapter knocking about, that opens up a whole world of options on an old frame...
A quick GIS for 'Peugeot Carbolite' suggests it's been done before quite successfully...
If your bike is a quill stem and it is too low an answer is a Nitto hi rise quill.
One piece better than an adapter.And Nitto stuff is just nice.
https://www.hubjub.co.uk/nitto-fu-82-quill-stem-4190-p.asp
My Plug has mechanical discs, so it must be one of those. A very fetching blue colour, with a matching blue stem that I think looks smart.
Just to illustrate what you can do with old 1" frames/forks here's a couple of my contraptions:
The Ridgeback (my commuter) uses a quill adapter to fit a modern 1-1/8" stem and 31.8mm bar.
The old Raleigh is using a traditional quill stem and a 26mm Dutch/North road type bar (flipped to use as a sort of mega flared silly Drop bar
The point is there are lots of (pretty cheap) ways to put just about any bar/rise you might want on an older frame...
Just get over to retrobike and wave £300 about, you'll soon end up with something that will be super comfy for commuting.
Failing that, and suggesting what you own. Have a look for the aluminum version of the Charge Plug, it’s not a harsh frame at all and takes 40mm+ tyres
Love mine, such a unique and versatile bike, rarely actually ride it but will never get rid of it, whilst slowly and completely unnecessarily pimping it up with hand-me-down components from other bikes 😎
Croix de fer.
Thanks for the advice.
I'm going to do a bar + brake lever change to allow me to brake from the hoods. If I'm still hunched over I'll fit a riser stem.
